Re: Sears 7.5 HP Crank seal?
I'm goin' in - Here's what I saw.
4
The dark zone on the crank kind of makes me wonder if there's not some wear there, but I'll mic it up later. The gasket under the stator casting calipers at .030" thick. I found a number on the block casting - It's 881998 This may help identify the Small Engine Warehouse short block ***'y they're selling for $65 or so, as a useable outboard block for 7 1/2 HP. If that'd work, it'd prolly be cheap as getting the upper and lower bearings and seals, with all the required gasketry. We'll see. Otherwise, onward, thru the fog!
Oh, yeah - Do the lines on that piston suggest replacement?
4
