Simple, easy to make DVA adapter for standard Multimeter
Status
Not open for further replies.
ixs
Re: Simple, easy to make DVA adapter for standard Multimeter
Hi
I tried to look in a catalog too buy the items needed for this meter
1N4007 Diode
https://www.elfa.se/elfa3~se_en/elfa/init.do?shop=ELFA_SE-EN#query=1n4007;in=prod;node=18884;id=1;
but there seem to be many to chose from.
"greencap" 0.47uF
https://www.elfa.se/elfa3~se_en/elfa/init.do?shop=ELFA_SE-EN#query=0.47uF;in=toc;node=0;
Many many more.
Finally the resistor 6.3Mohm
https://www.elfa.se/elfa3~se_en/elfa/init.do?shop=ELFA_SE-EN#query=0.47uF 630v;in=toc;node=0;
Can any kind soul please give me a hint wish ones to buy
so I dont ruin it.
Many regards
IXS
achris
More fish than mountain goat
Hi
1N4007 Diode
Stock number 70-005-16
ixsx said:
I looked at a lot of the caps on that site, and the best I can come up with is 65-578-47. The price is a bit over the top though. I pay about $1.50 for them in Australia...
ixsx said:
The resistor is something you'll have to go to a electronics shop to buy. Very few on-line stores will sell less than 1000 resistors at a time...
so I dont ruin it.
Many regards
IXS
ixs
Thanks achris for the trouble.
The price is not that bad, its in SEK, so the cost will go from 5.89 AUSD, to 5.89 SEK.
And that would be only 90 cent.
Do I go for the 1000v alternativs. or does it got to be 630 v on the "greencap"
About the resistor on 6.3Mohm. It?s difficult to find, not a standard value they say in the shop.
I am quite an amatuer in this, but I?m trying to check an old Mercury 1976 50hp.
The stator is next. And this is the thing I prosume.
Done the ohm-test but very tricky, the numbers are all over, flickering just locking at the meter.
achris
Ok... Didn't even look at the '.se' in the web address...:redface:
Anything over about 450volts is good..
You can use any value around that. 5.6MΩ or 6.8MΩ would be fine..
Chris......
Dunaruna
I'm glad IXS asked those questions because I was also having trouble finding the exact parts described.
Thanks for clearing it up Chris.
achris
Aldo,
This is the shop I use for electronics...
http://www.jaycar.com.au/stores.asp?State=Victoria#Victoria
The stock numbers for the items that you're needing are...
Diode - ZR1007 (that will cost you 60c, but you'll get 4 in the packet)
Capacitor - RG5247 ($1.95)
Resistor - RR1668 (pack of 8 costs 40c).
So for $2.95, some lengths of wire and some solder you have a $200 meter.... Pretty cool ah?
Chris........
Dunaruna
Very cool!!! :cool:
I have a jaycar store just around the corner, thanks.
Dunaruna
Just ordered everything online including extra DMM leads and mounting box. Even with delivery it was still under $20.
achris
Errr, just one question.... What exactly do you need a DVA for? You have a stern drive, either points (if it's as old as me) or TB-IV/V, which is troubleshot with a DMM...
Chris.........
Dunaruna
The 302 had a piranha retro fitted dissy. Sold Dunaruna 5 years ago, I wish I still had it but c'est la vie.
I now am the proud owner of a '92 70hp yamaha on a very early savage hull. This yammy has issues, it cuts out at random times for no apparent reason, starts up again without issue and goes for another few hours and then cuts out. It's not a fuel issue.
The hull was a giveaway (literally), it was destined for the crusher. Like I needed another project - not! I'm a sucker for punishment.
http://img.photobucket.com/albums/v259/Dunaruna/2005DunnaRunna2.jpg
http://img.photobucket.com/albums/v259/Dunaruna/P1010001.jpg
http://img.photobucket.com/albums/v259/Dunaruna/P1010016-2.jpg
http://img.photobucket.com/albums/v259/Dunaruna/5122008-RunaboutTrial-4.jpg
Speedwell69
What would the watts rating be for the resistor. Is 0.25watts okay would 2 watts be to high.
Thanks
Michael
j_martin
Thanks
Michael
That's a minimum rating for heat dissipation. No problem.
achris
The only upper restriction on resistor wattage would be physical size. As far as the actual dissipation, 1/4 watt would be ample....
Dunaruna
Thanks Chris! :)
$20 worth of bits and pieces and half an hours work.
achris
But does it work? :D
Dunaruna
No, but it looks good!
Status
