Starcraft project: "STOLEN" PIC UPDATE 7-31-09 COMPLETED!!
ezmobee
Re: Starcraft project: "STOLEN" PIC UPDATE 7-31-09 COMPLETED!!
It absolutely will.
HopeSheFloats
Congrats Andy, just fired mine yesterday for the first time since I got it a year ago :redface: putting the gear's to the test tomorrow :D {in a barrel, not yet water ready}
Those electric shifts used type 'C' which I believe is no longer available, I think you want to use 'OMC Premium Blend gear lube' but wait for someone more knowledgeable to be sure.
Huron Angler
Awesome news Andy! Your rig is going to fly with that 85hp.
Boatguy just splashed his 16' SS with an 85hp Johnson and he hit 46mph and he said it wasn't even wide open.
Well...as it turns out boatguy says his speedo probably wasn't working correctly and the numbers may have been a little off:eek:
Sorry for spreading bad info:rolleyes:
I will have my gps on the rig and hopefully get some speed trials going this weekend if I can get a few things figured out(trim/tilt).
What year is the 85hp?
Andy in NY
its a 1970. im hoping to at elast crack 40.
Andy in NY
boatguy94
:eek: I just ran across this... Sorry for starting the bad info, not your fault at all Huron. If I would have not been a bit under the excitement and had a perfect speedo this wouldn't have happened :rolleyes:
Hope you're getting your boat out this weekend Andy, I followed your resto this past summer when I had my Imperial, trying to get ideas and such. Great job!
Andy in NY
not this weekend... we were out of town till last night and going to a bbq later today. but this week i will be working on getting my 50 off and the 85 on the boat. i am waiting for my impeller to come in, as well as get a new oring for the trim pump. then it will be water test time.
Andy in NY
guys, i think im in barney...
all this time ive been thinking about why he sold me this motor so cheap... because it wouldnt start? because its electric shift? because the trim pump leaks?
today it hit me.
I DONT HAVE THE MOUNTING BRACKETS!!! This era motors have the 2 seperate brackets that bolt to the transom on either side of the motor. so i cant mount the motor!
found a set on ebay...
http://cgi.ebay.com/ebaymotors/OMC-...oatQ5fPartsQ5fAccessoriesQ5fGear#ht_500wt_750
are these universal or will i need to find a set specific to the motor?
ezmobee
For christ's sake Andy.....GIVE US SOME PICS OF THIS DARN 85 ALREADY!!!!! That may help :p
Andy in NY
new decals
also i have some questions about installing this 30 gal gas tank i have.
what size/type of fuel line? where do i mount the vent? the tank is going up under the bow.
also does anyone know a good source for battery cables online?
Andy in NY
well the motor is on, not hooked up yet though and not even bolted yet... i need to get the bracets still but this was the only time my brother in law could come help me...
after i sea trial i will repaint the hood and make it look pretty.
oh and i have a question... i think there are bees in the cooling system! sometimes i hear buzzing from possibly the water jacket?? is it possible? if they are inh there how can i make sure its not plugged up?
ben2go
Grab a cold one and sit back and watch the water intake to see if they're flying in.It is possible for it to happen on some OBs.
Andy in NY
well got some work done this weekend... turns out there was a bees nest right UNDER the tstat housing.
friday replaced the impeller and o ring in the trim pump. yesterday got it mounted up, tach installed, controls and trim switch installed and new battery cables made up. today we are hitting the water to test her out, barring any hard rain. the only thing i am worried about is the throttle cable, the metal clip that is supposed to hold it on the linkage is missing, so i need to make a way to keep it on there just for today. i will be ordering a new cable, but i need to make sure she is going to perform first...
cedarjunki
today it hit me.
why didnt you go back and see him? or atleast call him and see if he had any? he has piles of outboards sitting around!
i thought i had you a nice 90 horse merc.......until i saw the $900.00 price tag :eek:
hope it works out ok...
Andy in NY
i thought about it. but it was sold as is... and for cheap. i had no problem picking up all the things i needed that were missing due to the low sale price of the motor. after i pick up a throttle cable, i will be into the motor for around $300- $350...
you wouldnt happen to have any throttle cables laying around, would you? i think i may need a new trim pump too because its still leaking a bit, seems like from the manual release...
so you want to come out to chateaugay lake with your rig today in case this motor dies out in the middle of the lake??
woosterken
do a red green on it and put some duct tape on it LOL :)
woosterken
