Yes, I’ll keep going in this thread. Thanks for the offer on glass help, but this hull is aluminum.
My leaks appear to be the result of pitting on the top (inside) surface of the hull skin. The boat has a second welded-in deck on top of the ribs, so I can’t access the inside of the hull skin.
I’ll notice a pinhole leak, and discover that it’s really just the bottom of a pit that’s 1/4” or bigger. I probably find about a dozen pinholes like that each year. If I don’t stay vigilant, I might not discover them until they’re already grown to 1/4” holes. It can get out of hand quickly, and it’s why I run double automatic bilge pumps.
Since i can’t access the inside of the skin, my repair technique is to rough up the exterior surface, peen a dimple 2-3 times the size of the hole, fill the dimple with JB waterweld, and sand smooth. I’ve got about a 90% success rate. The failures appear to be from inadequate sanding, allowing the water to pull the patch off while underway. The smooth ones rarely fail.
I’m always looking for better techniques, so if anyone has a better idea, I’d love to hear it. I’ve considered using the Bondo that includes fiberglass reinforcement, beacause it should be much easier to sand. But I don’t know how waterproof that stuff is.
Any ideas?
