- Joined
- Apr 17, 2002
- 71,464
Re: Thank you fellow iboaters'
Ayuh,.... Welcome Aboard,.... I believe you've got a Crack somewhere...
Headgaskets don't dump water like that....
Drain it, 'n block off the motor's cooling passages, 'n pressurize with air.....
You'll Hear the crack,... follow the sound....
My guess is either the lifter valley, or the inside of the base, opposite the drain plugs....
So, after my first lake test I was checking over everything and pulled the dipstick to check the oil, yep water in the oil. And not just a little, it was about 1-2 qt. extra.
I am hoping I don't have a cracked block.
