Re: the 1967 Holiday 18 and Multiple Boat Syndrome
Osby---thanks for pic. always helps to see how the factory did it. the reason i'm thinking of routing em outside the console and straight down into the floor is to avoid cutting any holes in my til-now-waterproof console and more importantly, cuz i want to eventually put dual control levers on top of console so i can operate kicker from helm. i figure when i do that, i can put an aluminum cap over the floor hole. and i agree that gasket likely won't like any volatile hydrocarbons, gas or otherwise. figured i could get away with it since i'm replacing my filler hose so i shouldn't even have fume leakage out to where the gasket is.
GA---already stole this idea from someone. i have a hunk of 1.5" NM conduit under the floor, to be attached to stringer with loops of the old tiedown strap (don't trust it to hold boat on trailer due to sun rot, but it should still be overkill for supporting conduit) and brought up through floor on both ends with 90 degree bends cut down to roughly flush with floor level. electrics will run inside this one fore and aft from console, steering cable will be tied to it and hung from straps, and shifter/throttle cables will route down the opposite (port side) stringer inside another piece of sch40, albeit just water pipe this time. the info i'd run acros suggests making a drain hole rather than trying to keep conduit watertight....any thoughts there?
a couple more pix:
the completed dash cover....still need to add the trim piece in center to hide the join line
holes for deck plates are cut
(i got a deal on fleebay on a 5 pack of these a few years back so had these 3 lying around)
wasn't having any luck finding 5" straight rollers so i had to cut down 12" one....a new 18T hacksaw blade did great job, cut like buttah
while i was cutting the holes, figured i might as well take off the last 3/32 along the edge of floor panels....the edge of the 45 degree taper was so thin it was easy to splinter when fitting.
why you should bother walking over to the garage to use the hydraulic press instead of just trying to straighten the trailer bunk brackets with a BFH:
hoping i can salvage this piece, not just due to $ but cuz the new ones are no doubt far flimsier gauge metal
