Re: Timid but determined Glasstream restoration
OK folks,
We a having some technical difficulties tonight. My Computer is not reading my mini SD in it's adapter and I can't seem to find my card reader. So no new pic's for now.
Not much to report anyways. I had other things that needed my attention before I could work on the boat.
I did get most of the graphics off, just about 8 ft of pin stripe to finish.
I also got several of the areas in the back of the boat repaired. Twice. The first time I saw some air bubbles and ground it back out and refilled.
I got the entire bottom section of the boat sanded with 220, but I still have several areas to fill on the bottom but mostly just scratches and nicks in the gelcoat.
Now I have some questions.
1. What grit should I use to prep, if I plan to paint or re-gelcoat the hull?
2. If I decide to Gelcoat again how much of the old gelcoat should I remove?
3. When I was checking out the bottom of the boat I noticed a dip in the hull just to the starboard side of the keel. It's about 10" wide and about 1/8" deep. Just in front of the transom. Should I build it up and then fair it to get it level or am I worrying about something to small to matter.
I would appreciate any help.
I will post updated pic's as soon as I can get them to load.
Thanks again
Bob
