Re: Tire pressure question.
[QUOTE, I keep tire pressures 5lbs below the maximum.
I have ran it once in the heat of the day and had 3 blowouts, when done at night not one, I can't say that tire pressures had much to do with it,
I think the problem is simply too much heat built up in the rubber I suppose it should be stated that I haul butt, posted limits of course,
I see no reason to take it easy on long trips get there and relax is my way, I don't want to be on the road I want to be on the lake.[/QUOTE]
I think you just made the point...5lbs below max pressure, builds up HEAT, the higher the speed = MORE heat. A Hot day and you need every factor of safety you can get.
We've switched over to Kumho 857's in the shop and have solved a lot of 14" tire problems(only available in 14"). MORE load carrying capacity and Qspeed rated.
They are a little taller, so check clearance.
