Ok. So I researched this a bit to find out what exactly that button does to or for MY truck. For the 2007 Silverado Z71 I drive, the tow/haul button changes the shift charecteristics by increasing line pressure on the clutch plate packs, and increasing the engine speed at which the transmission shifts. It also allows for a faster shift, thus reducing slippage of components and preventing exsessive wear. It does not eliminate overdrive, which is any gear greater than a 1 to 1 ratio, but may cause the converter to not lock or lock at a higher speed. One of the recommendations was to use the tow haul to get up to speed, or when entering the highway, or of course in mountains and hills. Turning the tow/haul off during higway operation would allow the converter to lock and the transmission to run cooler. Hope this helps my fellow Chevy and GMC drivers out! Thanks everybody for your replies, and any additional comments or suggestions are always welcome.
It would be worth noting the engine temperature and transmission temperature as you drive the route with and without the boat, and with and without tow/haul when you are towing the boat. I think that info will inform your decisions.... You do have a trans temp gauge, don't you?
I use tow/haul and no OD when towing my enclosed car trailer with my 2500 Suburban -- even at 65. I use standard settings and OD when towing my 16' wood runabout.
Folks often focus on weight (which influences acceleration, braking, and tow vehicle 'levelness') and overlook trailer frontal area (aerodynamic drag/fuel "economy") when evaluating towing characteristics. Most boats are much more streamlined than cargo/camping trailers. In general, choosing the drivetrain settings that result in the lowest engine and transmission temperatures will be the best course of action.
Chip
A friend suggested getting a programmer. I looked at the Edge Evolution tuner. It has a power setting for towing. It reprograms the ECM and PCM. The guide does not say use in conjunction with the tow/ haul mode though. Anybody have thoughts or experience here?
never hurts to keep the fluid cooler i would do
Humans are curious creatures. If you're out to satisfy your curiosity get the tranny cooler, chip and whatever else tickles your fancy. If you want to tow something from A to B, you'll be doing yourself a favor if you keep your transmission from hunting.
Yes, you know generally how to tow. At the end of the day, you will lose at an alarming (100% rate) to the engine/trans computer, as it will kick your know-it-all butt in managing all the criteria needed to preserve the mechanicals involved in towing.
I disagree with that statement. While it may be true for much of the motoring public don't understand the mechanics of transmission and generally, that's ok. However those that do understand what's going on in their vehciles and the conditions under which they are operated, you need to remember that a team of folks in an engineering center decided how those algorithms would be structured. As such there is no 100% correct "automatic" operation. Here is just one scenario. Cruising on a flat stretch of road will eventually lead you to a hill and it doesn't matter how steep it is. With cruise control engaged, as the vehicle enters the grade, speed will begin to drop and the cruise control begins to add throttle. At that point MORE throttle needs to be added to not only make up for the lost speed but to add sufficient throttle to maintain that speed. If the grade is steep enough, the cruise control may not be able to compensate so a downshift occurs. Now -- consider this. If you are an attentive operator, you see the hill coming and experience tells you that cruise will not be able to prevent a downshift. So you accelerate just a couple MPH on the flat just before entering the hill which then allows you to overcome that initial lag before the cruise control realizes it is losing ground. You can then continue to remove you foot from the accelerator as you crest the hill. The extra fuel it take to accelerate on the flat is but a fraction of what it takes to overcome lost speed on a hill. No downshift occurs on even relatively steep grades. The problem with cruise control and transmission controls is that there is no "anticipator" meaning something must happen first before any algorithm can take place. That reaction must "overcome" the event rather than having a way to anticipate it where much less throttle is needed. So a good, attentive driver can indeed out drive cruise control. I do it consistently. To me cruise control is a convenience and does not provide the best economy. For most drivers however, cruise is the best way for them achieve optimum economy. The same principle applies to use of tow-haul or manual operation of the transmission.
Wow.. quite the informative and some what controversial subject! Previously I had posted what information I had gathered from GM technicians. What I know from that is: Tow/Haul is best for acceleration and driving on changing road elevation. One of the functions of the feature delays the engagement of the TCC(Torque Converter Clutch) which causes more heat because it is a fluid coupling versus a mechanical couplin when the clutch engages. If I am driving on a generally flat road surface and have acheived my desired speed, turning off the Tow/Haul mode will allow the clutch to engage and lower the fluid temperature and increase fuel milage.
On the GM Allisons, it's quite the opposite - tow/haul mode engages the TCC far earlier, as the TCC eliminates slippage. You get more power to the wheels. I use tow/haul whenever I have heavily loaded trailers - about 7k or more. The DMAX/Allison combo raises the shift points and increases line pressure as well.
