Re: Towing 3000lb boat OD off or on???
3.73's will work just fine for a small boat and even 3.42 is ok for some loads. A quick primer for the OP.
Axle Ratio: Lower gearing (the numerically higher ratios, e.g. 4.10:1, 4.56:1, as opposed to 3.31:1, 3.42:1), typically produces greater tow ratings because of greater torque multiplication. There is a wide variance in the axle ratio?s effect on the tow rating, with some diesel-powered pickups varying only a few hundred pounds; on others, changing from a 3.73:1 to a 4.30:1 sometimes increases the tow rating by 3,500 pounds. In the past, some ratings have increased by a factor greater than three (from 2,000 to 7,100 pounds) simply by using a different axle ratio. Lower gearing will also make your vehicle accelerate quicker up to 50-55 mph. In general, a one-step drop in axle ratio (4.10:1 to 3.73:1) on an HD pickup will drop tow rating and gcwr by a ton. Lower gearing has an adverse effect on fuel economy, but it?s usually not proportional to the gain in towing ability. Under the best circumstances, the difference between the highest and lowest gear ratios offered (say, 3.42:1 and 4.10:1) results in a 1.5-mpg decrease in non-towing, steady state-highway cruising. In most normal conditions that change is less than 1 mpg, and if you tow a relatively heavy trailer a lot, there?s no question that the lowest gearing is best.
The biggest thing about towing is the gearing. 4.10's are what you need.
