piper_chuck
- Joined
- Aug 30, 2007
- 83
Re: Towing with my van
The 2010 T&C, when properly equipped, has a towing capacity of 3600 lbs and a payload capacity of 1200 lbs. Pretty good for something that's (allegedly) only built for "light loads and passengers".
I suspect if you actually TALK to Chrysler you will find that towing is indeed one of the uses for which the T&C is designed. And if you could talk with the engineers, and lawyers, who came up with the towing capacity, you will probably find that the published limit is already a significant percentage lower than what they felt it could safely tow. Undoubtedly they made such a reduction as a house for their donkey.
Out of curiosity, is this a fact, or just opinion?Listen! I gotta say it! you should only be @ 70% of max tow capacity.
Not sure it's been shown that the OP cannot tow his boat, unless one applies some arbitrary limitation on the manufacturer's published towing capacity.If you want to buy a boat make sure you can you can buy, or have a vehicle that can tow it! if not buy a smaller boat!
And the fact that the OP asked, and is obviously listening to the opinions being offered, shows he's not in the category you're ranting about above.Most people buy a bigger boat that there vehicle can't handle, and then can't buy the proper vehicle to tow it! They'd rather have someone say...Oh yea! I do it! It can handle it! I drive down the road and see some outrageous idiots! and they put me and others in harms way, just so they don't have to buy the proper vehicle.
That might be the classification YOU have arbitrarily assigned to them, but the published specs, and the experiences of people who actually have them, clearly show otherwise.Mini vans are for light loads and passengers, If I recall there called passenger vehicles!
