Woodonglass
- Joined
- Dec 29, 2009
- 25,929
Wood, do you mean by drilling holes in the outer fiberglass skin? Or the 2 pieces of ply on the inside for the mechanical bond?
NO!!! Only in the wood transom!! We have a member "Nurseman" that, IMHO, did one of the best transom installs that's ever been done here on the forum. It's for an Outboard Boat but...the principles are the same. It starts here...http://forums.iboats.com/forum/boat-...69#post8278669
Install is here...http://forums.iboats.com/forum/boat...s-total-gut-and-rebuild?p=8512409#post8512409
and continues for several posts. I'd Highly recommend you study these posts and follow what he does. He used Poly resin but again the methods will be very similar. When you glue your wood together If you use the TB III I'd recommend using Deck screws as described in my link. Then once it's cured remove em and then drill the holes for the PB to ooze thru. If you draw a rough out line of where the Keyhole will be for the outdrive then you won't need ooze holes in that area. You'll need about a 1/2 gallon of TB III to glue the transom together. Maybe a little less. Make sure all areas are cover with a thin coat does not require a heavy coat. Pour it on and then use a plastic bondo spreader or a plastic putty knife to spread it around. It needs to be 60 degrees + in order for the glue to cure properly. Kinda like Resin!!!
