transom
mwassman
i have a big problem. i just became the owner of a 15' alumacraft side console with a 35 evinrude. the back is decked in with storage compartments and the wooden transom is riveted between the deck and the rear of the hull. well the transom is rotten and i'm trying to replace it but i would have to drill a bunch of rivets to to take the old one out and put the new one in, i really need to keep the back as light and as strong as i can get it the motor is a little biger than it needs to be.
thanks
1983rinker
Re: transom
If it all rotten, you must replace all. You have photos??
Woodonglass
Re: transom
Rinker has it right. Pics will really help us to help you. There is NO easy way to fix a transom the RIGHT way. LOTS of ways to do it WRONG!!!!
I'm just sayin...:D
Re: transom
There are no short cuts. Dig in and remove what you have to in order to access all of the rotted wood. You can use Nidacore or Seacast, or simply build a new wood transom (to size), glass, etc., and you're good to go. What I have learned from my rebuild (and I am still learning) is that, 1.) the contributors here are some of the greatest guys on earth and 2.) there are no short cuts 3.) Keep searching and reading and asking questions.
Good luck on your project and above all, have fun!
Steve
Woodonglass
Re: transom
Did the wood go all the way down to the hull? Does it go all the way behind the boxes back to the sides of the hull? Are the boxes alumawelded to the hull or are they riveted? Are the Angle braces on the stern riveted or alumawelded? If rivets then drill out the rivets, remove everything so you can get to the transom wood, remove it all. Fabricate a NEW transom using standard ext. grade plywood back to the same thickness as the original. A 35 hp motor should only require about a 1" transom. Two pieces of 1/2" ply and a couple of layers of 1.5 oz mat and some poly resin should do the trick. Pay close attention to the edges to ensure everything is sealed up tight. If you drill any holes, make sure to seal them up when you put the screws or bolts back in. If the wood does not go back behind the boxes then it should be fairly easy to replace. If it's all alumawelded then you're gunna need to find a good alumawelder. Get a grinder and grind the welds off to remove everything. That's the RIGHT way IMHO. Others may have a different opinon.
I'm just sayin...:D
Coho Ghost
Re: transom
Wass,
I would check out NIDA core pourable transom compound. IMO it is easier to work with than Sea-Cast and a LOT cheaper. Also, the NIDA tech folks are a big help with the project.
Coho Ghost,
Up in Washington state.
1983rinker
bonz_d
Re: transom
Slightly larger pictures with more detail esp. in the area were the boxes join the transom would be of great help. Also of the top cap of the transom and how it is attached.
tintug
Re: transom
Here are some pics of mine. I opened it totally up though mine had stainless steel screws and bolts in it. I used the old transom wood for the templet made the new one , then coated it with "gluvit" and put it back in. I need to update some pics.I haven't been workin on her much due to it being hunting season but I am ready to get back after it... Good luck.. There is plenty of help on here. http://s220.photobucket.com/albums/...=slideshow&track=share_email_album_view_click
1983rinker
Re: transom
what I did today with my transom.
mwassman
Re: transom
thank you for helping me out on this, ive done a transom before just not one that i had to cut welds and drill so many rivets i'm worried about hurting the hull integrity of the boat. all under the decking in the back that i cut out to remove the transom was filled with dens foam, will it be necessary to place that? also ive read that truss head bolts with nylon lock nuts are best to use after drilling rivets but would that be fine for the bottom of the boat or should i put rivets back in? i haven't drilled any rivets on the bottom yet but i think i will have to because the is a transom support on the port and starboard side that each have six rivets in the bottom
mwassman
Re: transom
good progress, had to cut out allot of aluminum. just trying to put it back together just as strong as it was before, i cant use any of the original aluminum so i thought of using aluminum angle for bracing
bradseagraves
Re: transom
Looks like I'm doing the exact same thing you are. I have a 1976 Rhyann Craft. The transom was about 70% rotted. Not sure how it was holding the weight of my 35 HP Chrysler. I had to cut a few brackets and also cut the top of the side boxes in order to get all the wood out. I'm going to start putting the wood back in within the week.
Any suggestions on a particular resin to hold wood together?
mwassman
Re: transom
i used behr outdoor wood sealant which is for deck sealer but i put allot of coats on it and i backed it with silicone between the wood and aluminum. you can go to your local paint store and they will probably advise you to use some special epoxy or paint with a name you can hardly pronounce and cost allot $$$. with the the transom being a vertical surface and with todays marine grade wood i think you shouldn't have a problem with a cheaper outdore wood sealant or paint. if you have any other questions let me know, mine came out great and with zero leaks so im happy with it
Re: transom
One has a choice, and for my project my choice would be epoxy, glass, and marine wood--plywood is fine if you wish as long as you seal it well. Go cheap and you'll do it again. If you need a caulking, use 3M 5200 marine.
Yacht Dr.
Re: transom
1983rinker Tell us you did not use that plywood for your transom!
Hey..easy...I tell the wife to cook me turkey din din..she brings me chicken .. same thing right ? OSB for transoms..Now I think she is feeding me pigions ;) .
YD.
