scipper77
- Joined
- Sep 30, 2008
- 2,106
Re: What does this button do?
I had a similar non working horn minus the blown fuse and I wasn't sure if the switch or the horn was the problem. I hardwired 12 volts across the horn and the wire I used melted off the insulation instantly. I learned two lessons that day...
1) Fuses prevent electrical fires!!!
2) when bypassing the fuse panel to test a device use very small wire so in a worst case scenario the test wire will melt before the real wires do.
