wire diagram
dadwayne
son has a 120 mercury inboard motor, amp gage when turn key on is maxed to end, battery dead in less then hr. if take all wires of battery except positive and negitive still maxed. got new alternator and the red and orange wires are on same post on alternator, power on all time alternator , could this be the short . need diagram to show how starter, alternator hooked up?
thanks
wayne
Don S
Re: wire diagram
Might want to add things like YEAR, Merc does change things occasionally.
JustJason
Re: wire diagram
I betcha you got a seperate voltage regulator screwed to the transom.... and that's yer problem.
But you need a DMM to cheggit.
dadwayne
Re: wire diagram
1987 wellcraft 19 1\2 ft
165 mercury
plus where would a person get a manual for this boat?
in Canada bought USA
Don S
Re: wire diagram
Original post April 28th, 2008, 08:22 AM
Man, you sure do take your time about answering questions :eek:
First of all, if it's a 165, it's not a 120.
The 165 is a 3.7L (aka 470) engine.
Up in the adults only or DIY sticky at the top of the page is Mercruiser manuals. You need #8 for the engine, #6 for the drive.
The charging system is NOTHING like a 120.
JustJason
Re: wire diagram
Heck this has to be a close to a record for an OP reviving his own dead thread.
Dadwayne.... Head up to the DIY section in the main forum thread section. You can find manuals in there.
