FLATHEAD
replied to the thread
My carb is obsolete.. Please help me repair/replace!
While I agree that non ethanol fuel is good stuff and I use it. I will say that it can certainly go bad. I can’t count how many...
Apr 16, 2026
R
Rickf
reacted to
Crosbyman's post
in the thread
Evinrude 50 4 stroke 1999 been setting, need to restart suggestions/ guidence
with
Like
first thing is to get a manual and compare results to specs. it may flag a problem more than swapping or guessing but... ex: see sect...
Apr 16, 2026
Power steering fluid in bilge?
easy to pressure test the cooler. they are easy to repair too
Apr 16, 2026
T
Toddavid
Got it. I suspect a popped power steering cooler. We’ll find out tomorrow when I get to fire her up.
Apr 16, 2026
Mercruiser motor swap
with an 80 gallon tank, we are not taking the boat out as much as we would like, considering the average boating trip is 40-50 miles...
Apr 16, 2026
suggest draining prior to using the block-buster kits. Volvo Pentas only close cool the block and heads, not the intake. so unless you...
Apr 16, 2026
W
wn6ngp
Just fyi, I have 2000 90hp elpto. I started off using gasohol. In about 2010 I started having problems. I cleaned the carbs and all...
Apr 16, 2026
T
Toddavid
I winterized it the same way as I’ve done for the last 10 years of ownership. It’s closed cooling, so I hook my 5 gallon pink stuff...
Apr 16, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
I made the mistake of touching an area of the fiberglass that had been ground . . . ouch . . . microscopic fibers in my finger :oops...
Apr 16, 2026
P
Pmt133
I ran a 19 for cruise which was a bear with a full boat, but still got 45-4600 wide open with load. Tubing was a 17p 4 blade and it was...
Apr 16, 2026
Ted, you still have grinding to do. you are not completely thru the gel yet
Apr 16, 2026
M
Mc Tool
reacted to
Bugzilla46310's post
in the thread
Motor support racks
with
Like
If the combined center of gravity stay within the perimeter of the base, an item will not fall over.
Apr 16, 2026
redneck joe
reacted to
tpenfield's post
in the thread
with
Like
Interior grinding is done. I still have the grinding outside the transom to do . . .
Apr 16, 2026
redneck joe
reacted to
beta's post
in the thread
1995 Crownline 202BR Restore
with
Like
FYI... got an answer from the engine forum. It's 92-25234 Sound blanket glue, but this has been superseded by Bellows adhesive 86166Q1...
Apr 16, 2026
redneck joe
Exhaust to Gimbal Connection
Lower shift cable as well?
Apr 16, 2026
