We're Gonna Get Hammered - Oil Spill!
DECK SWABBER 58
Re: We're Gonna Get Hammered - Oil Spill!
Todays the big day.
The four story "capture dome" is going down.
jay_merrill
New info that probably has not hit national news yet - the cofferdam arrived on site late today, but it could not be deployed, because the fumes on the surface are so concentrated, that the captain of the ship said it could not be safely done.
So, for the time being, at least, the cofferdam approach is not going to work.
In the mean time, the slick has made landfall on some islands that are not very far from the bulk of the marshes.
marlboro180
I had actually wondered how they were going to work in those conditions. Good call on the Captains part- putting further lives in jeopardy would be a real big mistake. Too bad on the further delay, seems like the marshes are too close to call.
Hope for better tomorrow.
jay_merrill
More news - apparently the wind has picked up a bit and has cleared the fumes sufficiently for lowering on the cofferdam. It is on its way to the bottom now.
Keep your fingers crossed!
Bigprairie1
We are all watching and pulling for you guys....good luck and let's hope this hits the mark.
BP:):cool:
rbh
Has anyone heard any comparisons between cleaning up light sweet oil and heavy crude, I know the point may be moot but just wondered.
DECK SWABBER 58
Todays USA Today has a good diagram of what is going on down on the
ocean floor and how the cofferdam is hopefully going to work.
If you haven't already, take a minute and say a little prayer for the safety of the guy's out there now.
jay_merrill
I haven't heard/read any comparison between cleaning up the crude that was spilled in Alaska v. this crude, but don't get too attached to the term, light, sweet crude.
As this oil makes the journey up through a 5,000 water column, the lighter components separate. The heavier components are still lighter than water and continue to rise to the surface. When this portion of the crude first reaches the surface and is agitated by wave action for a bit, it becomes about like "Noxema Skin Cream" in consistency. After days on the surface and exposure to air and sunlight, it thickens even more. What is now on the surface is a gooey, red substance that is more like mud, than any sort of a film.
Having this coat the marshes is going to be a big mess. It probably isn't going to be possible to clean them, so there are possible plans to simply burn the marshes, at some point in time. What has not been decided, however, is when to do that. Our marshes and estuaries provide a great deal of hurricane protection. In fact, one of the reasons why Katrina did so much damage, is because we have lost huge amounts of marshland over the decades. As such, our leaders are leary about burining the marshes before hurricane season is over this year. If we go ahead with the burn, we could be giving up what little protection we have left, until the marsh grasses grow back.
Unfortunately, this is to a large degree, a "take it day by day" situation.
jay_merrill
Update: The cofferdam was successfully placed. They will now let it settle into the bottom and begin hooking up pipe to bring the crude to the surface.
rbh
Thanks Jay-
I just wondered what the consistancy differance was, "noxema that floats as to tar balls that sink.
As I look at it the on this "friday night" rushes/grass may be you biggest saviour, if they can trap the oil, they are easly removed and burned.
I hope they don't try to sink any more with chemicals, as that just screws up the sea floor life.
DECK SWABBER 58
That is wonderful news.
I know the tough part is yet to come, but let's keep our fingers
and toe's crossed that they can hook that pipe up.
Jay, keeping posting, the "main stream" media is more concerned
with.... Not going to say another word, I want to keep this thread
going.:rolleyes:
THANKS JAY,
KUTGW.:)
jay_merrill
The first attempt at using a cofferdam to cover one of the leaks and recover oil from it, has failed. It seems that a buildup of "icy hydrates" has cause the box to become too bouyant and has clogged the choke point in the cofferdam, where the extraction pipe was attached.
As of now, the box has been lifted and placed about 600 feet beside its original resting point. Another box has been under construction for some time, but isn't much different in design.
DECK SWABBER 58
Sounds like they have no idea what to do now.:(
Except keep drilling the relief well's.
Well all we can do is keep our fingers crossed and
see what happen's tomorrow.
marlboro180
Any updates from your perspective Jay?
jay_merrill
Well, I just spent 30 minutes writing a long response to fill you guys in on the latest info, but "good ole VBulletin" dumped the submission. Grrrrrrrrrrrrrrr!
The Unified Command web site is OK, but the information is several days old. As of this writing, a second, much smaller cofferdam is sitting on the seabed, being hooked up and otherwise prepared to be reset, over one of the leaks. This one is only 5 feet tall and 4 feet wide. Apprently the thinking is to use a smaller one, because they can better control the temperatures that caused freezing and hydrate buildup.
What I am waiting to see, is if they can keep the thing over the break in the riser pipe. This cofferdam only weighs a couple of tons and the oil/gas is flowing out at a pretty good rate, so I am fearful that it will just lift the unit and make it ineffective.
I guess I should be more positive, but things haven't been going too well thus far, so I guess I am a bit skeptical.
I'll fill y'all in on mroe info, as I get it.
Cofe
Thanks for the update, I hope something works soon.
Not to hijack, but if you write a long response while loged in, only to see it vanish when you hit submit reply. Just click your browser back button untill you get to what you just wrote. Highlight the text, right click and select copy. Go to Iboats again, log in and respond again, by right clicking in the text area and select paste.
Seems like there is a time out on writing reply's.
Hope this makes sense. Thanks for your efforts Jay!
