Re: Stihl Chain Saw Oil Mix 50/1
He was referring to me.
All modern ashless 2 cycle oils can run 100:1 IF THE ENGINE IS DESIGNED TO RUN 100:1. That requires centrifugal scavenging and oil routing to bearings.
An old engine, like my 1928 Graham Paige rototiller 2 cycle engine, requires 16:1, whether it's 30W non detergent, or a modern ashless 2 cycle oil.
In short, the oil mix depends on the engine, by design. I'll stick by the designer's instructions. You mix it any way you wish.
The 400:1 jab was a direct quote from advertising tripe, probably by the manufacturer of the oil you use.
My 02
John
