jrttoday
Thread starter- Joined
- Feb 8, 2010
- 1,081
more of the same.... Guessing we are all familiar with this death trap.... hit the trim and it all fell apart. Just needed a measurement
everyone's busy, can't get a hand, as usual. Not even going to tack it while it's attached to the unit, but because of close tolerances, need to see where it works best. As straight as possible in line with trim rods is best, but due materials and what I "can" make (and have made) might not allow for that.
A missed communication or what, makes no difference now ? I take full responsibility. I had only looked at the tilt cylinder pin and said its 5/8?s. Marked its position on the inside and transferred the mark best as I could.
Made all of the preparations to drill and thought to measure the pin against the bit; pin was slightly larger - and longer than I remembered. Decided on the machine shop again, but first welded pieces to thicken those brackets with additional weld to hard surface the holes; and then ?hurriedly? center punched the hole again.
Am certain I told him to find the center of the radius marked inside and transfer that for the hole instead of using punched mark. Other than that, he did another great job; including threaded grease fitting passages for the steering tube holes (which I was going to do but since he had it.....)
The pin fits real tight; fairly easy to get the pin started, but hammer in. It all works well, but will have to bend a hydraulic tube slightly to keep it from rubbing on the factory bracket for reservoir, with full trim only.
New bushings and shims, plus two carb kits arrived today - maybe soon!!
