1988 Starcraft Mariner MR 220 V rebuild
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
There is no engine on the boat...looking!
Ah, ok. Thought it was already reinstalled and working. Saw the picture of fish and figured you took it out.
So any updates from the mechanic or still pending inspection?
SHSU
dizzyspots
SHSU
SHSU...the boat was a charter out of Puerto Lobos, MX 25 ft center console with TWIN 250 Mercs...1st day was pretty windy with 3-5 ft swells, but Sunday we nailed them...had a blast...The 220V is a winter project. Going to start with the splashwell removal and transom replacement. WHile im there, Ill check the status of the floor from underneath the deck near the bilge. With a covered deck (thick pain, carpet, vinyl, etc) what s the best way to locate the rivet path to get then drilled out...any diagrams or landmarks?
dizzyspots
Got it home safe and sound, gave it a 1st bath with Meguiars Heavy Oxidation remover...great winter project...!!
SHSU
No such luck. That would make it to ease. lol
Best bet is to pull up the carpet/vinyl and look for the rivet heads. You should see them along the edges and where it follows the stringers.
SHSU
dizzyspots
dizzyspots
Trying to group the rebuild pics in one area...bear with me...got the transom out..new one is cut..glue and screw and seal this week...floor removal starts tomorrow..prior owner covered rotten floor with 3/8 ply and white roof coating...more to come...I'll try to locate and delete earlier posts..so everything is in one spot...
dizzyspots
Seat is out...console is out..both at the house for cleanup and rebuild...
Moserkr
Chief Officer + Starmada Splash Of The Year 2021
Welcome dizzy! Good looking fishing boat project you got yourself. Did she come with power or you looking for something?
dizzyspots
Old transom out..new one glued and screwed ..finesse and sealing over next couple of days...pulling up some more of the "overlay" and original floor tomorrow
SHSU
Transom corrosion, a common theme on these old hulls.
SHSU
dizzyspots
Got the top layer and the bottom layer of decking off..working on the foam...ugh!!..Bonus find..prior owner installed a poly 52 gallon fuel tank and found a 10amp on board charger under the starboard gunwale...
sidingguy
Don't you just love good suprises after finding not so good suprises? My shop is full of stuff I found in compartments that didn't get cleaned out before I drug the project home!Nets ,anchors,fire extinguishers,fishfinders,tackle,first aid kits,dead possums,squirrels and other deceased life forms.
dizzyspots
So...as were taking the side panel off..that runs along the floor...found a Lite beer can.."best by date" was 1996!!!
Watermann
SHSU
Every last one, I almost miss that smell of old dirty gym socks and moldy cheese when wheeling it off. :rolleyes:
Watermann
A mod can merge the threads for you, not sure why you started another one though? @jbcurt00
dizzyspots
Thanks Waterman...not enough computer savvy...should have asked my 12 yo LOL Cheers
GA_Boater
All one thread now.
