Eric 3.7LX Alpha 1
- Joined
- Mar 27, 2010
- 3,008
What year is your 470, or the serial number? Mercruiser used used two different styles of distributors. The Delco and Prestolite. Which one does your cap look like? Also, once you set your dwell and point gap, then you have to check your timing. Moving the point gap/dwell will change the timing. Timing is checked after the dwell. There was a TSB issued regarding timing. It was lowered to 4°. I have the TSB attached below:
Or this one:
Or this one:
