Volvo Penta V6-240 Fuel High Pressure Dropping to Zero
harringtondav
I'll run some more .rec, at temp and different RPMs and post them tomorrow, if I can.
To attach a .rec file, open the Diacom 'record' file and right click on the file or files you want to attach. Select "Compress to...", and select 7z file.
It will take a few seconds before the 7z file shows in the folder. These can be attached.
Biz603
Try to get this back into one thread with this message.
Ok. Many good points above. I'll try to answer all of them. If I miss something let me know. I'll do the tests listed below this weekend.
1. I'm going to pick up an Ultraviolet fuel additive and put it in the gas supply. If the relief valve is dumping into the crankcase (or bypassing the piston) I will see it on the dip stick with a UV light. Will let you know.
2. I'll get a scope on the signal to the HPFP and try to record what I see.
3. Regarding the battery. Interesting points. Open to trying a different battery if it helps. I purchase the boat from a Cobalt dealer in 2017 with the following battery in it. DieHard part number 24M-AGM.1758675355207.png
This battery lasted 6 years then I purchased the same one 2.5 years ago to replace it.
Just purchase a brand new one tonight, put it in and no noticeable change.
4. The only rubber fuel supply line runs from the tank to the fuel filter. To eliminate it and possible fuel tank screen clogged or fuel line check valve issues, I took this line out and ran a new line from the filter to a separate 5 gallon gas can. No change. Same issue.
5. Regarding the HPFP - Started with a new Volvo HPFP. Same issue. Then purchased 2 new GM pumps and tried them, replacing the fuel pipes each time. Same issue.
6. For reference, this is a model V6-240-C-J engine. Its governed to a speed (or interpolated RPM) request and tries to hold that requested RPM.
7. Just found out why the .rec didn't stick. This site didn't like them. No big. I ran new once tonight, on the new battery, will add them to this reply as .txt files. You'll have to download them and change the extension to .rec. One is a 18 minute run with several minutes of warm up at idle before increasing the RPM by 500 RPMs and holding for 1 minute before increasing another 500 RPMs, until failure. Another is just a quick throttle up. And the last is a Misfire .rec. Needless to say, all still failed at the end. I held the requested RPM high for seconds after failure to see what it would do. It didn't sound good. Engine was struggling to stay alive. Didn't feel good about holding this too long. You can see this in the first two files. I haven't reviewed them yet. They are hot off the engine.
  • Volvo 0923 Quick Ramp.txt
  • Volvo 0923_18 Min Run.txt
  • Volvo 0921_Misfire_1.txt
Biz603
I've never used OBD equipment on a marine engine but I diagnose vehicle engine problems everyday. On a car P0174 would point to lean mixture on bank2, on this boat engine the 0174 code also seems to point to lean mixture on bank2. The way it detects mixture is using an O2 sensor, the boat engine seems to have O2 sensors because the OBD information includes readings for mixture.
If the O2 sensor on bank2 were bad that could maybe account for the engine going into limp mode? In both 'OBD snapshot' tables posted by @Biz603 in post #24 closed loop fuelling is disabled and the 'readings' from the O2 sensors seem unlikely to be correct because they point to an absolutely correct air fuel ratio. In practice the air fuel ratio usually flutters around 1 (where 1 is correct, above 1 usually lean, below 1 usually rich) so we might expect to see numbers like 0.997, 1.002 etc. At high engine load the engine normally gets a rich mixture so the reading is usually below 1, on a car it might go to 0.9 (you could read that as 10% rich). A lot of OBD systems on cars will create fake numbers for components they have deemed to be not working properly, they might give an A/F reading of 1 pointing to absolutely correct mixture for a failed O2 sensor.
Summing up, I'm suggesting the O2 / lambda sensor on cylinder bank 2 could be at fault...
See posts above. I replaced both O2 sensors and all the fuel injectors and the bank 2 trim fault went away. It did seem like it was in limp mode, but it turns out its just this problem we're trying to troubleshoot now. Basically the engine dies at >4300 RPM because the HPFP pressure is dropping from around 2050 psi down to below 30 psi even though the commanded RPM's stay high.
muc
"Retired" Association of Marine Technicians...
I don't know how to convert these into .rec filed. Can anyone help me?
harringtondav
You can attach the .rec files in a 7z zip file.
Open the Diacom 'record' folder and right click on the file or files you want to attach. Select "Compress to...", and select 7z file.
harringtondav
Interesting. I believe the VP 4.3 DI engine is a GM 4.3 liter v6 ecotec3 lv3 for the most part sans exhaust manifolds, cooling, ECM etc.
I wondered if you got the Delphi/Delco p/n from the VP HPFP. I was poking around an found the HPFP at a considerably lower cost than VP.
I buy only boat OEM parts when they're proprietary, like drive parts. But when they're stamped with other OEM p/n's like this I feel safe purchasing them and saving a lot on the cost.
Biz603
Inte resting. I believe the VP 4.3 DI engine is a GM 4.3 liter v6 ecotec3 lv3 for the most part sans exhaust manifolds, cooling, ECM etc.
The GM part number for the pump is not on the VP pump, but it's not on the GM pump either. After realizing the VP engine was the GM 4.3 V6, that you mentioned above, used in the Chevy Silverado 1500 (2014-2019), I ordered the GM HPFP (p/n: 12744840). It looked identical, QR codes and everything. Saved me a ton of $$'s. In fact, like you say, many of the parts on the engine are most likely GM parts. Injectors, fuel pipes / rails, spark plug coils, air intake manifold, many sensors, etc. Not the low pressure pumps, exhaust manifolds, cooling systems, or ECM.
