Thanks for the deep look and trying. I appreciated it.I'm at a lost for what it could be and have been reading intently hoping to find the issue. Hoped @muc or others can advise, but looks like the well is running dry
Thanks for your input. Open to trying it.The only thing I come up with is a different hpfp... 12733993 for the 4.3. Looks like it overlaps the pn for the one you are using. Do I think thats the issue based on the data? No... but I'm at a loss for what else it could be.
2017.One other question. When installing the fuel pump, how's the lobe look?
And I don't know if I missed it but what year 4.3 is this?
It's odd to be having the same issue but something is being missed.
The lobe, eccentric, cam lobe etc. Just checking. I've seen worn lobes from fuel pump failures cause issues too but usually it's noticeable either in the fuel or visually scarred or worn down. I don't think it was the problem either but worth asking just to rule out anything else.2017.
Not sure what the lobe is. But, after removing the HPFP each time I looked down the hole at the cam it rides on. Admittedly without a flashlight, but under sun light I didn’t notice any excessive wear or scarring. The push pin on the HPFP looked good. Can send pix of that if needed.
The latest . . .Sorry I didn't visit this forum for a while but I checked this thread as soon as I visited... Just don't have anything to suggest.
Any new developments?
Can do. So I understand, what’s the reason?Please don't exceed 2000 RPMs when not underload.
Good question, made me think about why I always give this advise.Can do. So I understand, what’s the reason?
So... it just fixed itself? I'm with an 5.3 genV volvo penta engine and its showing the exact same problem as yours was showing. Im not an english native speaker so maybe some words are not all right but i will try. I have read all your posts and its literally the same error. I have changed the pump 2 times already, new injectors, new fuel line pressure sensor, new hydraulic tappet that goes to the fuel pump, and still when i reach 4000rpm the fuel pressure drops to 50psi just like yours did, like something was shutting it down. Have no idea why. If you have any new things to add that you maybe discovered throuout time let me know, it can maybe help me very much, im trying to figure out this motor for at least 4 to 5 months by nowSo, last day of May 26' and I'm reporting back as promised. Broke the boat out. 'Springerized' it. Fired it up on the trailer, zero issues. Full 5800 RPM on demand. Looking good. I'll drop it in the water and give is a good test under load in a week or so. I'll report back then.
