Mercruiser 4.5l low vacuum, WOT 4350 and higher fuel consumption
muc
"Retired" Association of Marine Technicians...
Didn't know you were on the other side of the pond!
I have NO idea how this might affect anything.
The only thing I know about prepping a boat for Europe is from many years ago having to install a special transformer for shore power on a boat heading there. That was back in the Days of MEFI so you might want to call Merc if there is anything about the PCM 112.
CONSUMER SUPPORT for North America is,
Mercury Outboards / MerCruiser / MotorGuide
Phone: 920-929-5040
Maybe they can advise?
Captain of the Double G's
timing, and that 32f reading still bothers me, if u are not using that system install it. In the meantime replace the TMAP again. Gut feeling and you still do not have a HZ reading.
Now I can solve your problem completely. " I should have had a V8 " old school chevy ( small block , pick any but 305 with a 2 barrel rochester carb, we are done.
muc
Thats correct. Not sure what's the logic of this PCM. Speed and density controlled. There is no IAC just throttle drive by wire. Guessing that PCM calculates air density from vacuum and temperature (TMAP sensor) and adjusts injector pulses to keep stichometrtic ratio. How does the RPM stay steady at idle with low vacuum IDK maybe controlled with timing?
Reason I want to pull the intake is to check valve lifters. But that after few more checks before that.
I really don't think you have a problem with lifters or cam timing. Your fuel trims look too good. But if I had some good O2 numbers I could be more sure.
Also with the electrical problem you have, all bets are off on these numbers.
The PCM Diagnostic manual gives a little info on how all this works. Like I said it uses many different "tables" to adjust all this stuff. Unfortunately all these manuals are written for a Mercury trained tech. So I'm guessing it might be pretty hard for the normal person to understand. Good Techs spend a lot of time learning this stuff.
muc
Spark advance looks pretty good to me. But once again --- low cranking volts could affect this.
Did you mean ° degrees or % percent?
What sensor are you thinking of?
But that does bring up a somewhat exotic possibility. I've never seen it, but in class the instructor does bring up the possibility of the RELUCTOR WHEEL slipping on the crankshaft. I've never had a 4.5 apart so I'm not sure if this engine is keyed (can't slip) or pressed (can slip)
nola mike
Yes I did remove oil cap - no smoke there.
Did not check timing old fashion but will it work if PCM controls timing and shows already -3 deg at idle?
Broken valve spring - don't think so compression 180psi each cylinder.
I will definitely remove intake and check valve springs and clean hydraulic lifters, gaskets etc, but that after summer. I've got still two weeks in marina and then will take boat on trailer.
Exhaust checked no restrictions.
14.7V but all sensors getting correct 5V.
I know that PCM can double injector pulse time if vaccum is incorrect - see once more attached ECM555 logic. I believe PCM112 works similar way.
Vaccum is way off at idle and I hope I will find the reason.
That doesn't explain your fuel consumption. Your vacuum looks ballpark once you get off idle. And unless you have the specs, you're just guessing that it remains off throughout the rpm range.
nola mike
I don't suppose there's a cam position sensor on this?
muc
Nope, not needed with this system, just like no knock sensors.
Only used on the new stuff that has VVT - variable valve timing.
muc
What do you see wrong with fuel consumption? It's tracking with MAP, Demand and RPMs
O.P. has never stayed stable on the throttle long enough to get into ARO (advanced range optimization) where they will get best fuel burn. This is one off the things Diacom doesn't display like G3 does.
nola mike
I don't... He was saying he thinks he has increase fuel consumption because of his vacuum being low (and posted a table). I didn't think that was his problem
jimmbo
Yank all that Electronic Crap off, replace it with a Carb, and Mechanical Advance Distributor, if you want to have many years of trouble free boating. But if there ever is a Problem, much much easier to figure out what is wrong, and fix
muc
Now that I am an outboard guy, my knowledge on the Mercruiser front is quickly fading :oops:. . . but just taking a look at the data, a thought that came to mind was the throttle plate. (loose, linkage, something.) :unsure:
Yes but still helping on the MerCruiser front. i looked up one of your Diacom files to see your MAP readings.👍🏻
muc
You'd be able to tell if the reluctor on the crank slipped...
If it walked out of position, yes.
If it spun a little bit, that got rather involved.
But I’ve never had to do it, so not 100% sure.
durban
I connected a Morey,s upper cylinder lubricant vacuum line to my Rochester 2 barrel carb , at idle the vacuum used to be 15 in Hg now its at 20 in Hg.
muc
Funny thing—- maybe because I understand the new systems, I find them easier to diagnose. Especially if it has cats.
Another funny thing—- even though I work in an industry that turns fossil fuel into CO. I still have some pretty strong opinions about pollution and what it’s doing to the planet.
Back in the days of carbs and points, we would have to open the doors in the winter if we ran a boat in the shop. We tried a CO detector and had to get rid of it because it was always sounding.
Dealer I’m at now has automatic monitoring and ventilation, have to run two or more EFI engines at a time to trigger it. We don’t work on anything over 20 years old.
i have seen a keyway " broached , it is a term for extending I believe. I have seen a keyway being sloppy from use and causing timing issues, I can not believe I forgot this, it was one of my hardest diagnosis
muc
I connected a Morey,s upper cylinder lubricant vacuum line to my Rochester 2 barrel carb , at idle the vacuum used to be 15 in Hg now it’s at 20 in Hg.
The other side of that coin.
These newer engines will alert you before they ever get that carboned up, so it will never happen.
Sold a new EFI 10 hp last month, we wouldn’t take his 1994 10hp on trade because it was too old Even though “it runs really good”. He called two weeks later and was all worried it wasn’t using enough gas. Said it using less than 1/2 of the old one. Told him that was normal.
Is this new tech worth it? Guess that depends on how much $$ you have.
muc
They didn’t mention any problems with the keyed ones in school, good to know.
I’m guessing that at least you could poke something through the CPS hole and get it to wiggle.
