Thanks jig...I'm just trying to do half as good as you boys! Psycho-as you can see in the first pic, 2 coats of white didn't even come close to covering. I did thin the gel with styrene at about 10%. I used the white kinda like a primer, knowing that the gray would cover better after. I surely could have stopped at the 2 plus 2 mark, but needed to add the sand, which by the way Sam, was just common beach sand. Had my helpers been there earlier in the day, probably would have added the sand after the first coat of gray, then top with a couple, but I'm just winging it. I have no proof that this method is going to be successful in the long run. My son tried Kiwi Grip in his last build and at $70 a quart, I was not impressed nor have I been since his splash. Don't think it holds up well at all. He later used the sand method on some wood flooring inserts he custom made for his little 14' polarcraft aluminum, which you can often see in the background of some of the pics on this thread. He had already tried the resin only and we now know that doesn't stand up to weather for long. He ground it down, used/experimented with the gel/sand and it has held up nicely for a couple of years. In addition, this boat sits out in direct Florida sun, at all times. I figured it's worth a shot...and saved me some moolah, too! The worse that can happen, if it doesn't hold up....I'll grind it off and lay it or something else again. I know the structure of the boat will hold...just trying to protect it from the outside and make it look like something I can be proud of. I guess I can be the guinea pig/pioneer of this method and like most crash test dummies...offer another option..if it works. The one thing that does concern me is the likelihood of staining. Sam and I have discussed this before. It seems rolled on gel stains quite easily and I have yet to figure out how to seal it to prevent this. Hey, like I said...things could be worse...as long as it's fish slime/blood that is doin' the staining!
