Re: 1971 16' ss
I did a little calculation (see below). Some have said you should be able to "squish" some of the air gaps out, I don't know. My boat had pour in foam and I spent 4 weeks getting it out. I will probably go with sheet foam, but I haven't ruled out the pour in stuff either. Once I get done fixing rivets and applying Gluvit, I may go pour in if I feel 100% I got the leaks fixed. The inside of my hull looks like Starcraft applied Alodine where the pour in foam would be. There are a couple spots where either the Alodine wasn't stuck good (or whatever) that did have a little corrosion, but not alot. I also wonder how much quieter the hull would be with pour in foam over sheet foam or noodles. As far as laying down plastic, I believe North Beach stated the pour in foam would react with it and melt it. FWIW.
