1971 Winner Bimini 17' Tri Hull
fstorm08
Re: 1971 Winner Bimini 17' Tri Hull
Quick question.... should I glass the underside of the new deck when I get to that point?
Ksmith0110
I used a pre-treated 3/4" plywood sheating for the deck in mine, and I put the treated side down, and resin on the edges. Then the top was covered with csm & resin. I'm not sure if it was the best descision or not, in hind sight I think I'd have at least coated the underside with resin. But what was there lasted for 37 years, so I think I'll be okay. The original deck was 5/8".
fstorm08
Thanks for the responses.
I'm thinking of doing 1.5oz csm on the underside, then a layer of 1.5oz csm on the top. Next a layer of 4oz cloth then a final layer of 1.5oz csm.
Or would 2 layers of 2.0oz csm be sufficient on the top of the deck?
fstorm08
Does anyone have any suggestions on this?
Should The deck be a min. of 8oz. total?
I will probably just roll on some gellcoat for a textured finish instead of carpet.
Woodonglass
If she were mine, I'd use 1.5 mat and then finish with 1708 Biax. Your Grandkids will be using it for their kids.
fstorm08
Well I am celebrating Christmas in March (for me) :) :)
I'll post pics of the goodies I got tonight once I take some pics tomorrow in the daylight.
Thanks T!
tlzimmerman
Nevermind this...thought I replied to my own thread.....
Nice boat!
fstorm08
Woodonglass
How bout mixing up some thickened resin and tearing/shredding some 1.5 oz mat hair up and mixing it up to peanut butter consistency, sand, wash with acetone and spead it on the hull. Redrill the holes and it'll never rot again.
fstorm08
Hummm... good suggestion wood.
How thick do you think it should be and how far out to either side?
fstorm08
What about multiple layers of 1708biax, each over lapping by about 2 inches??
Thanks in advance for any advice
Woodonglass
I'd make it approx. the same as the wood was so that the existing bolts would work, and fair it into the hull. It will be plenty strong and solid. One thing tho, I probably would suggest using epoxy instead of poly, it's a LOT stronger and does NOT crack as much.
fstorm08
Thanks Wood!
I really appreciate the info!
fstorm08
Well I decided last week to take tomorrow off of work to pull the boat out of the garage and start grinding..... come to find out we may get 8 - 10 inches of snow....WTF!
fstorm08
Well no grinding done yet but I did come across somemore fiberglass supplies :)
prepping for some warmer weather! :D:D
