Re: 1975 evinrude 9.9 fuel pump prob?
Bktheking, Uh hum... looks like you got the first cookie! Glad you're still with me, bud. I re-read posts #9 & #2. Will & I pulled the carb, keepin it level, & the bowl was completely full. We measured the float drop to be 1-3/8", right in the middle of the recommended range in the OMC manual. It seems that, for whatever reason, the carb isn't pulling fuel from the bowl into the manifold. I blew compressed air through all the passages (I think) & ran a piece of wire through all the ones under the soft plugs. How many times, I don't even remember. I bet I can get that carb off faster than anyone! I've never seen the 15hp carb kit or the seat you're talkin bout, unless it's the same one that comes in the 9.9 kit, for the mixture needle. The local dealership mechanic says he never installs them, that the needle seats well without 'em. In fact he gave me four spares outta his toolbox! What "seat" is stuck in the carb you have? I might need it anyway, 'cause I have my "ways" of gettin things unstuck. I'd probably like to have it!
Fed, HE77 YEA, the compression numbers were a GREAT relief for me. Confirmed my work on the internals & the "opinion" of the local machinist about not really "needin" to go +0.10 on the bore & rings! I also learned to beware of the length of the threads of compression testers. Not all of 'em will fit inside these little motors!
OptsyEagle, I'll continue to check on the details, but thanks for pointing out that difference in the throttle cam. I looked at different year models a bit before that last post, & it can get REALLY confusing. At least I don't have to worry much about winterizing down here. I'm still wantin to FISH! I will, most likely, buy an entire carb, but I'll go with the 15hp, if I can find one, cause it's the only big difference in the two motors. That & a prop & I'll be FLYIN THE BAYOU!
Will Bark, If you find that link to contact Leeroy, Please forward it. I don't think I ever saw it, as many times as I have viewed his links. I also thought I saw a pic of the two carbs from the "down the throat" view & I couldn't find that either. I think I'm just really tired.
