fireman57
- Joined
- Aug 24, 2004
- 3,811
Re: 1976 johnson 35 surging
I would say that the points being reset should cure it. The surging might have been caused by uneven spark fed to the coils. The reason we went to fuel right away is because usually it is a fuel problem, uneven flow due to stuck float, crap in jets, gasket letting air in etc... I believe you will be estatic when you run it. Didn't realize that you had ever had the flywheel off for the points to have been moved or did they just move themselves from wear?
