1979 Imperial
GT1000000
Re: 1979 Imperial
Way to go Brutha Bear! You are making this look EASY-Peasey...Thanks for edjumacatin us wanna be glassers...
Jon Sob
Re: 1979 Imperial
Great job bear ...... very impressive! Excellent work.
bear_69cuda
Re: 1979 Imperial
Nice! My next resto I am going to try the tear method on the CSM.
Love the sound of that brutha! Jay's next resto! I'll be doing the other side of the transom today...
Can you do me a huge favor when you do this can you please take pics . This is the step im kinda pondering to my self.
Im going to wrap my new transom just like you are doing but i was wondering how i was going to stick it to the outer skin .
Thanks Rob.
Hey Rob,
I'll try and document as best I can... This is all new to me.... Brutha Jay has everything you need to know on video here if you get tired of waiting for me.... http://www.youtube.com/playlist?list=PL02C318B574CD948D&feature=plcp
Great job, bear! It looks awesome! I expected nothing less from you!
Thanks my brutha! Glassing is good times!
BEAR!!!! You're rockin brutha!! Way to go. Keep showing us the way! I only hope we get close to those results, it looks awesome!
Hey Craig,
Hope it's not blind leading the blind.... :eek: I'm surfing man, I figure I can just grind all my mistakes away! :D
You cats are the pro's man! I'm as green as it gets! But thanks for the kudos, it's great with you dudes covering my back, and all the support!
Thank you brutha Jon!
bear_69cuda
Re: 1979 Imperial
Hey gang,
I really like glassing... It's a mess and stinks, but it's very relaxing... Here are some pics of the bilge finished side of the transom from yesterday... Very solid!
Today I flipped it over and ground down the excess glass from yesterday with 36 grit, and prepped the surface for glassin'....
This time and from now on, I'll have my work area more organized and staged, instead of wingin' things like I did yesterday. I had 4- 500 mL resin containers, and 4 MEKP syringes locked and loaded! Also a barrage of cleaning supplies on standby... This made the glassin process way more enjoyable!!!!!!!
This is 2 layers 1.5 oz CSM on the skin side of transom... BTW I used the chip brush and glass roller! Made a huge difference with bubble removal!
I'd like to do more glassing this weekend, but Jackson needs a walk, and some Bear time... He's been such a good dog while I'm in the garage glassing, and tinkering for hours... I roasted a turkey today, so I'm sure he's expecting some of the kill with his dinner!
Have a great rest of the weekend!
Woodonglass
Re: 1979 Imperial
Brother Bear...I'd say you're pretty much a natural at this glassin stuff. R U sure you ain't lyin to us and you been doin this as a side biness!!!! That is ONE SWEET GLASSED Transom. Soooo.... you like that Bubble Bustin Roller Huh!!!!!:cool:
Rollinunknown
Re: 1979 Imperial
Your Glass job looks sick man! ..
It almost looks like a piece of candy haha.
Trooper82
Re: 1979 Imperial
I concur with the others....looks amazin'....
I know what you mean about your best friend....mine knows when I am heading out to work. Jumps for the door to tag along. Then sits in yard while I work. If I take a break, he comes right over for a visit.
Good to have the company.
Anxiously awaiting more updates.....keep it up
jbcurt00
Re: 1979 Imperial
Yep good looking glassing on the ply! Well done!
craigweaver
Re: 1979 Imperial
sweet Jesus that's some fine lookin glassin there Bear! lookin good.
bear_69cuda
Re: 1979 Imperial
Not sure about a natural, but I'm gettin' the hang of it.... Side biness.... hummmmmmm..... The roller really helps with the bubbles...
Thanks for the support boss!
Kinda like butterscotch candy~! Thanks!
Hey troop, yes Jackson can't wait for some boat time either! Thanks for the complements, and stoppin' bye.... Hope to get transom installed this week, and laminate my keel stringer...
Thanks brutha!
right on man! Thanks!
glnbnz
Re: 1979 Imperial
That is one nice transom you have there Bear!!
How is the box vacuum working for you? I tried to use one but I don't think that I have the right kind of shopvac. It is okay though I got my primary grinding done now and the boat cleaned up.
bear_69cuda
Re: 1979 Imperial
Hey Glenn thanks!
Benn looking for some updates on your build brutha...
The WOG vacuum works great! Make sure you remove the filter inside the vac... The box will be filled with dust and crap, but the vacuum will remain strong...
bear_69cuda
Re: 1979 Imperial
Hey gang,
I was all stoked for the weekend! I was gunna PB my sweet transom in... NOT!
I was test fitting it tonight and somehow it's warped ~ 1/2" so sitting in place there's a huge gap between the skin and the transom... ( it's not in backwards either )
I laid it on top of two vertical 2 x 4's and can clearly see the bend. In a last ditch effort before starting over, I parked my GMC Yukon on it, in hopes it can bend back... I dunno, my glassin seem kinda tough.... as Jas says! RAT FARTS!
I'm deflated...................................... :(
jbcurt00
Re: 1979 Imperial
All may not be lost, is the 1/2" gap run top to bottom of the ply transom?
If it starts low enough to not interfere with the cap going back on, go deep w/ the PB across the 1/2" gap & clamp w/ just enough pressure to insure contact & but to not warp fiberglass boat skin.
bear_69cuda
Re: 1979 Imperial
The apex of the gap seems to be in the middle from top to bottom of the transom. I can clamp the skin to contact the top, and the cap fits, but the skin will be slightly warped toward the bow if I PB it together... But I really hope your idea would work form me brutha. The xtra deep PB did come to mind, but I just wasn't sure?
jbcurt00
Re: 1979 Imperial
As long as your careful to not draw the 'glass skin into the cup in the ply wood, it's just extra PB, but I don't see how it's a problem as long as its well PB'd & no voids......
Woodonglass
Re: 1979 Imperial
Pics Please!!!! I can't SEE the problem
Oh wait... I re read your post and now I understand. Ok. This migh work for you.
Place the transom between 2 saw horses lay some towels on top of it. Soak em in BOILING HOT WATER and then set some HEAVY weight in the middle. Keep it HOT. Keep an eye on it and don't let it warp the other direction. It MIGHT delam the the glass not sure.
Pmccraney
Re: 1979 Imperial
Man, that stinks... And that transom was so puuuuuurdy too --- looked like caramel cake! I'm with Coonie (that's jb)... all may not be lost.... Since you have got an outboard and the you are not needing super-precise specs (for a key-hole, etc...), all you are after is strength back there (for the weight and push of the o/b)... Thus, I would see about just just flattening it out with planer/sander, etc... and then if there is still a gap, fill it in with pb.... (of course, that sounds like a bit of work and it may be easier just to start over). I wouldn't clamp it - not only would it look bush league, but it would eventually want to delam on you as it fought to go back to its original (out of the mold) shape...that's why I had to cut mine out and start over...
Just to be sure.... you are sure the wood is warped and you are not dealing with a curved transom, right?
If its any consolation, I have been working on my transom since November... seriously, its been that long.... So, it sucks to be you right now, but probably sucks worse to be me.. :facepalm:
GT1000000
Re: 1979 Imperial
Bummer Heavy Sigh..:facepalm:
Hope the gang can come up with a solution...
