Woodonglass
- Joined
- Dec 29, 2009
- 25,929
Re: 1979 Imperial
Cradle looks Great! Shop Vac filter will clog but you can make a filter box out of a cardboard box and it works great. Get a box big enough for the vac to fit in and cut a hole in one side for the hose fitting to fit. Seal it with duct tape around the hose. Cut out the outer three sides to openings just shy of the dimensions for air conditoning filter. Tape 3 filters to the inside or outside of the box with Wide masking tape. Remove the filter from the Vac, close up the box and go to town. the exhaust from the vac will be captured by the filters and they will last longer and can be removed easily and the dust knocke out of them to be reused. I've seen it done and it works great.
