1986 21 ft starcraft cc restore
jspano
Re: 1986 21 ft starcraft cc restore
some more pic of paint un-drying
[/IMG]
look at the green paint(?) under the red. i think it might be that ecthing primer, how should i prep that for repaint?
[/IMG]
if the weather co-ops i might get the last of the stuburn red off
jspano
does any one know if this tank would fit my boat ? (it's flipped right now i can't measure)
length =82(doesn't matter i think) Width =23 (between the stringers) Depth @ v =10 Depth @ sides =7.5
jasoutside
Well, I am thinking that you don't have any stringers or a deck on yet, so, it should fit just fine, eh!
jspano
yea that's the problem, i don't want a big lump in my deck and can't measure!
150.00 on cl 70 gal would be sweet
jasoutside
Yah a 70 gal would be super cool! I think you'd be fine prolly. The gas line fittings would likely be higher than where your old deck used to be but you could always raise this one up if you wanted to, maybe???
jspano
i know i'm not there yet but couldn't resist playing around. my idea of alum cleaner(much less than sharkskin)
cleaner
[/IMG]
finished product
[/IMG]
[/IMG]
jspano
i'm getting ready to prime. i'm using self ecthing primer, how heavy do i apply and is there any prep needed before the reg paint? it seems if i were to try to sand the revits would be bare again.
do i just do a light dusting then paint over??
i need some direction on this
HopeSheFloats
Not for sure here, but I used the etching primer on my upper sides...couple of light coats, but full coverage, then I hit it with 400 grit lightly to knock the fuzzies out of it...real lightly, just sorta skimmed along it.
jspano
thanks kenny
i will try a couple of light coats and scuff with a green pad
was hoping for more input
thanks again
ezmobee
Pretty sure a light dusting is all that's needed.
Bob_VT
That is zinc chromate primer that was applied at the factory :) looking good!
jspano
EZ and Bob
thanks
this painting thing is wigging me out... not real good at it.
i want to do a really good prep figuring it will help the most.
going to fix a few revits that i know are bad and i want to seal all the new ones before paint. i only plan on doing the bottom right now let it dry good and flip and put back on the trailer then do the rest
thanks again
jasoutside
Wish I could help ya out buddy but I am about ten steps behind ya!
I sprayed my transom with two thin coats of self etching zinc primer. My "PLAN" from here is to do a very light sanding and then first coat, second coat, very light sand (maybe) final coat.
Mind you, PLAN at this point.
I'll be watching how you shake out!
Have fun!
jspano
i think i'm thinking too much... but it keeps me from thinking that i'll be 53 tommorow!
but HSF you got me about trying to put gluvits in hard to reach spots maybe this will help
rivets
[/IMG]
gluvits in a sringe
[/IMG]
rivets and gluvits
[/IMG]
man i need to get a hobby
HopeSheFloats
I used the zip lock baggie trick, CheapboatKev & I discussed the other night...worked a charm, leak free, foam fun tomorrow!
Happy pre-birthday as I might have a few in your honor tonight and totally forget tomorrow lol....'52' here in Nov. My tub{boat not the wife :p} will be 50 next year :D
jspano
[QUOTEHappy pre-birthday as I might have a few in your honor tonight and totally forget tomorrow lol....'52' here in Nov. My tub{boat not the wife } will be 50 next year
][/QUOTE]
thanks HSF
my tub (my wife not my boat) will be 51 in aug
"Hope She Forgets" about iboats and doesn't see this
jspano
hey do you think this guy's wife made him sell this boat cheap?
[/IMG]
talk about murphy showing up!!!
SBTOM
Woahhh... looks like he is glad he had a strong safety chain!
jasoutside
Oh my gosh, is the boat ok???
Yup.
OK, whew that was close. That could have been really bad!
