1986 ss 201
Status
Not open for further replies.
dozerII
Re: 1986 ss 201
Up front, perfect spot for the juice holders!
I really like this build.
It's definitely giving me ideas! :D
Thanks Jason, DH83
Hi Glenn, you're still keeping the starting battery in the Stern correct? If not, you're going to need a honkin' cable to make that 20'+ run (knowing you, it's probably already there!)
EDIT: I just realized what TM stood for...nevermind; this is the ideal setup for the BMTM :)
That's right the starting bat is in the port rear compartment.
Great battery solution, DII. Probably one of the best! :D
A couple of solar charger Qs. Will the solar panel charge the SS and 5th wheel at the same time? Does the travel trailer have a genny you could plug the SS into? I'm asking because I always read that a solar charger can help maintain a charge but they have trouble re-charging a drawn down battery. That's the little solar panels, do you have a large panel on the RV?
Thanks GA, I have one 85 watt panel now and am going to ad a second. I have two 140 amp hour bats on the fifth wheel now 104lbs a piece and they never go below about 12.4 volts even after two weeks at the lake. With the second panel my Battery guy says if I run the two TM bats down 50% on the SS, it will take 4 days to bring them back up with one panel and less than two days with two panels. I don't use the TM that much but if I do I could bring my generator to bring them up faster.
dozerII
Re: 1986 ss 201
Okay, as off right now, battery install is done( one switch left to bolt in) HIN tag is on, CG capacity Plate is on, Cleaned, polished and Armoralled everything.
I'M calling this one COMPLETE :whoo:
As complete as one of us can call a project.
Still have to make a bra for the bow for trailering on the gravel, but that's not part of the boat.
Tomorrow will engine run up prior to the Splash May 10, cus May the 3rd I'm off to meet Gibbles to pick up the next project.
GA_Boater
Re: 1986 ss 201
Starcraft on the water almost. I bet your happy to be done with the SS 201 so you can start another.
dozerII
Re: 1986 ss 201
Actually GA I'm going to take a break for a while. All I've done for the last two years or better is rebuild boats. I'm going to have fun at the lake and watch Clist for deals. I want to build up an inventory of good hulls for rebuilding as my retirement plan. LOL
barato2
Re: 1986 ss 201
now that is downright decent of you, sir. gotta let some of the rest of us have a shot at SOTY awards.......;)
beautiful boat, and i love all your low buck engineering!
budski
Re: 1986 ss 201
Hey Glen, Congratulations, but we know you're not finished with that SS 201 always something more to do or add, excellent spot for the batteries, looks like it was custom made for them, I have a question the cable you used is it battery booster cable looks like it, the reason I ask is I was going to use 8 guage booster cable for my trolling motor 55 pound cavitation mount minnkota and the battery is front center, just wasn't sure if it was heavy enough.
jasoutside
Re: 1986 ss 201
Congratulations Glen, congratulations to you buddy!
These big projects are pretty easy to start, very hard to actually finish. Well done my friend:thumb:
Really looking forward to seeing her float man:joyous:
GA_Boater
Re: 1986 ss 201
I know we're gonna see you on Hoarders. LOL.
bob johnson
Re: 1986 ss 201
now that you are bored, can you come on over and help me ?????ill let be the supervisor
bob
InMotion
Re: 1986 ss 201
SWEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEET!!!!! Fab work man! Congrats on getting her finished and lookin' awesome!
Just a splash to complete the whole process and to enjoy the fruits of your labor!!!!
Jim
SKDave
Re: 1986 ss 201
Awesome job!
Sounds like you are picking up the 18' v5, should be another great project
classiccat
Re: 1986 ss 201
Congratulations Glenn! Your work is inspiring!!!
boatnut74
Re: 1986 ss 201
Congrats on getting it complete. Just a few short weeks and you can be on the water. Putting the batteries under the floor looks good, nice and tidy and out of sight.
dozerII
Re: 1986 ss 201
Thanks B2, everyone's got a shot at the SOTY
Thanks John, I used 4 gauge welding cable for the leads to the trolling motor, the bigger you go the better.
Thanks Jason, and me too, never have seen her on the water!!
Thanks GA
bob
That would cost big time.lol
Jim
Thanks Jim
Congrats on another GREAT build!
Thanks JB
Awesome job!
Thanks Dave, heading down next Friday if it all works out.
Thanks BF16
Thanks Drew,one of the guys was down at the lake today to fill a propane tank on a cabin, and the lake is still froze solid other than a 2ft opening at the shore.
GLG fishing
Re: 1986 ss 201
Nice job DII it's been a pleasure to follow along.
Sending some some nice weather your way to help with the ice off.
Good luck with the splash and hope everything runs smooth.
GLG
dozerII
Re: 1986 ss 201
GLG
Thanks a bunch GLG.
dozerII
Re: 1986 ss 201
Poured some gas in the tank, two jerry cans of premium, (only way I could get non ethanol) $64.00 yikes. Filled the water separating filter, pushed the throttle 3 times turned it over, throttle again and the 4.3 came to life. Purrs like a kitten. The only issue is the tach is not working. I think it may be set on the wrong setting. Here's a couple pictures of her outside on the second nicest day of the year so far.
And my favorite, don't realize how big she is till she is hooked to the back of the truck broad side.
GA_Boater
Re: 1986 ss 201
And a resurrected SS201 roars to life under waving Maple Leaf flags. :D And back to waiting for more than 2 feet of open water. :eek: You have to be itching (in a good way) to splash her!
Status
