I began a rebuild on my 125 HP Force motor back in 2020, had to replace the cylinder block because it overheated real bad resulting in scored cylinder walls. The previous owner had it rebuilt too, which included boring cylinders to max oversize.
Many life experiences got in the way after tearing it down and finding all the parts I needed, so I had to put the rebuild on the back burner, WAY back burner. Now I'm back at it and have the engine block put back together, head is on, carburetors are on. I got to a point where I needed to refer back to all the pics I took of the motor before I started tearing it down and several during the process. Unfortunately for me, I can't find anything other than some pics of the wiring.
I was hoping someone on this forum has the same motor and, if you don't mind, able to take some pictures of the 3 sides excluding the head side. This would help me a great deal with finishing putting it back together.
I would greatly appreciate any help anyone could offer, even if it is simply websites that may have photos or diagrams I could refer to.
Thank you!
Hi, JerryJerry05, I've gotten plenty of help from you in the past, mostly prior to the tear down.
Thank you!
