Re: 383 Build
Steve, I know exactly how you feel at this stage. Research is your best friend. I had never built an engine before so I bought a few books on SBC building. I started with Rebuilding the Small Block Chevy Step by Step Video Book, then How to Rebuild Your Small Block Chevy by David Vizard, and How to Build Big Inch Chevy Small Blocks. I also bought a few others just because I get obsessive. I already had Dennis Moores Marine SBC book. I then slowly figured out what parts I wanted. Yea figuring out the piston-head-rod combo was the most difficult. I really wanted good quench.
Here are some of the parts I went with:
Enginequest Heads 200cc and 72cc combustion chamber.
SB Chevy 383 Mahle Forged -16 D Dish Top Pistons to work with 6" rods
Scat 383 4340 Forged Standard Weight Crank - 3.750" Stroke
Scat 4340 Forged Pro Stock SBC 6.000" I-Beam Rods - 7/16" Cap Screw.
Lunatti Roller retrofit lifters. 1.5
Clevite 77 bearings
RPM air gap intake
Q-jet jetted for 383
etc etc.
Static compression of 9.1:1
Quench a tight .035
As you can likely see I spent a fair amount on the engine.
As for deciding on the cam I took the guesswork out of it and called a custom cam designer and had one ground for me. Cost a little more, but you get a cam matched to your components. I asked for one with a smooth idle and good around the dock manners, and no chance of reversion as I am through leg exhaust. That was more important to me than maxing out the performance.
The engine was night and day compared to the 350.
Again research is your best bet and before you buy stuff run your combination of parts by some of the guys here. It will save you buying the wrong stuff. Don't ask how I know.
Clevite 77 bearings
RPM air gap intake
etc etc.
Quench a tight .035
