KathyD19
- Joined
- Jul 17, 2012
- 352
Hey everyone, need some more advice! I've taken my restored boat/motor out on the lake 3 times so far since getting it up and running and it's fired up and run perfectly. Until today. I was getting ready to take my mom out for the first time on it (in more than 40 years!) so I had it in the water and gave it a little test run. It idled at neutral just fine but when I shifted into forward it jerked hard then began to run forward alright but when I opened up the throttle a bit, it slipped back into neutral. I checked it at several different throttle positions and it didn't matter if it was slow, medium or faster, it would. out of the blue, slip back into neutral with a jerk. The only thing different from when I last ran it was that I had to take the hood off to do something to it so I had to remove the shift cable but I re-attached it just the same as it had been. When I have the motor turned off and I push the shift lever forward and back, the lever on the motor moves accordingly just fine. So it seems to be slipping out of forward when running but I don't know what to do to adjust that? Help?
