70hp johnson stalls only at idle
ryanr623
Like the title says. If I leave the warm up lever on it will keep running. If it stalls at idle, i need to put the full choke on to start it back up. It will run with warm up lever down only if i have it in gear and giving gas. 1975? Johnson 70hp 3 cylinder. BTW Compression test was EXACTLY 130 PSI across all three cylinders.
tashasdaddy
Re: 70hp johnson stalls only at idle
sounds like either dirty carb, or idle speed stop screw needs adjusting. you should be idling, in the water, in gear, 650-750 rpms. great compression, have you check spark and all 3 cylinders?
ryanr623
I am doing that today (checking spark). I am changing plugs because they looked bad....black. I will check the spark at that time.
BTW BEAUTIFUL dog. Pure Siberian? As soon as I move out of my twinplex (too small) I will be getting one of my own.
tashasdaddy
pure siberian. was abused, i rescued her. sweetest thing in the world. loves boats.
ryanr623
God bless you, how could anyone abuse such a beautiful dog. Any animal really. I have a very low (no) tolerance for animal abuse
clemsonfor
my abused (not by me) rescued dog loves boats also!
-nate
Hi i have a 1974 checkmate boat with a 1984 235 evinrude outboard. When ever the boats trim is all the way down and its running at idle it cuts out. what can i do to stop this problem
tashasdaddy
zebrowskicheckmate, start your own thread, hijacking some one elses is very rude. thank you.
Scottycat
Ryan:
Did you ever find the problem?
I have the same issues, exactly, and trying to fix.
I hate when things don't run right.
-Scott
