Like the title says. If I leave the warm up lever on it will keep running. If it stalls at idle, i need to put the full choke on to start it back up. It will run with warm up lever down only if i have it in gear and giving gas. 1975? Johnson 70hp 3 cylinder. BTW Compression test was EXACTLY 130 PSI across all three cylinders.
