sprintst
Thread starter- Joined
- Apr 18, 2009
- 2,066
Re: 77 Starcraft Holiday 18 i/o - rebuild with pics galore
Now some pics of the wired up fuse block, wiring harnesses going in, switches getting wired, etc. It's not that bad at all as long as you can trace a wire to see where it goes from your existing panel, etc. I'm glad I tore mine down as there were grounds to the hull, all over the place. Each ground wire should be going back to the neg on the battery or a neg bus bar, etc...not connected to the body like a car.
It's more expensive to buy it wired up but by the time you buy the marine wiring, connectors, etc here in Canada you are better off just buying the kit in the US and plugging it in. Mine was the issue with time and not being to easily get the wire, etc locally.
