saginawbayboater
- Joined
- Mar 8, 2012
- 677
Re: AeroCraft York 1960ish Transom, Stringers, Deck
The Pro's say that PT wood is OK in fiberglass boat construction as long as it's dry. It is usually very wet! It is not acceptable for aluminum boat construction because the chemicals cause a galvanic corrosion response.
Thanks kfa4303
Lookin' good! Does it matters if you use pressure treated wood vs. non-pressure treated? Can the chemicals that preserve the wood have an unintended reaction with the resin and/or glass? Just curious.
Thanks kfa4303
