pecheux
Thread starter- Joined
- Jun 9, 2006
- 1,200
Today on my small boat trailer (800 pounds capacity) I removed the hubs, cutter pin, and outside bearing and packed the inside with water resistant grease and remounted everything back. Then I was told by a neighbor that saw me do it that it should not be packed and that air is needed inside along with the grease. Do I need to remove some grease ? Or is it ok the way I ve done it ?
Thank you.
Thank you.
