Crazy gas saving scheme, will it work?
lockey32
Re: Crazy gas saving scheme, will it work?
ok i've been looking at this for a while and i belive it will work not just as an additive but as a replacement for gas. i built a small chamber and it works fine but it pulls to many amps .my 2000 rager putts out 80 amps . i found the plans for this thing for free but i can't read the blue prents for the control box that make it work at low amps. here is the web site http://www.fuel-efficient-vehicles.org/FEV-hydrogen-generator-build-one.php
studlymandingo
I'm probably showing my ignorance here, but besides the obvious (well water instead of a dedicated passive ground loop; presumably used for cooling only), isn't that just a type of geothermal heat pump?
How could anyone reasonably doubt it's effectiveness?
What are your thoughts on the implications of using well water vs. a dedicated ground loop? I.e., electricity cost to run your well pump much more than you would otherwise, long term wear & tear on your well & equipment, etc. Obviously in the short term you're saving $$$, just wondered if you think your short term savings might be mitigated somewhat in the long term by those other costs/ factors (as compared to a dedicated ground loop system). And no, i don't expect them to be 'mitigated' to the point of costing more than retro installation of a dedicated ground loop : ).
For the life of me, I don't know why we can't (don't) utilize geothermal systems to a much greater extent than we do. I know that dropping circulating loops for a geothermal system is expensive, but I've gotta believe costs would come down significantly if we did it a lot more (as contractors became familiar with it and the technology improved)... Your thoughts?
The reason anyone doubted the system design was mainly because of lack of complete understanding of how the system works. Many commercially produced geothermal heat exchangers are a tube-within-a-tube which is exactly what I built; I just did it on the cheap. As far as the wear and tear on the system goes, I'm not running a lot of volume of water as it doesn't take much flow to make the heat exchange. Even with the ground loop you still have a pump dedicated to circulating the exchange fluid through the loop. With anything mechanical there is always the potential for failure, the well pump motor can fail just as the condenser fan can on a regular condenser. I have municipal water so the well was only used for irrigation; I now capture rainwater in a cistern from my roof that is used for irrigation so the well is right now only used for my air conditioning.
I agree, we should be doing a lot more geothermal systems; I am a general contractor and I know why it isn't done more. It is upfront cost; unfortunately most buyers aren't looking at long-term and overall cost, they are interested in how much this 3/2 costs versus that 3/2. There is going to have to be a major shift in consumer thinking; unfortunately it may take something like $4.00 a gallon gasoline. Oh, wait that's here now!
I am currently doing a home here in Florida that is totally off-grid, uses 100% captured rainwater for all of the household water use. That water is filtered dependent on end use, then the greywater is sent through a constructed wetlands inside the home that grows plants for food as well as filtering the water that is then used for toilet flushing. The blackwater is sent to a solar septic tank that speeds up anerobic processes, the effluent is then sent through an exterior constructed wetlands which contains things like duck potato, papyrus, reed, willow, and cattail as well as other tuber plants that extract heavy metals, excess nitrates, phosphates, and pathogens; in addition, there is a microcosm of bacteria that forms on the root system of the plants that further cleans the water to a point where it is safe for irrigation usage outside. The permitting process has been an arduous process for this home because it is different. I have partnered with some local universities to do testing on the water quality to report to the state who is issuing an innovative use permit for the onsite wastewater treatment system. Doing this build we are having workshops to try and promote some of these sustainable practices and show people the practicality of some of the systems. That way if gasoline ever gets to $4.00 a gallon, people can start saving money at home so we can help keep big oil afloat!
Robj
I have not read all the posts, but I have worked with these systems for diesel engines. The theory is that it is supposed to increase the efficiency of the combustion process thereby increasing the power and decreasing fuel consumption. I have worked on a couple of diffferent systems, have tested them on the track doing SAE type 2 fuel consumption testing, on the dyno and even out in the field. I have yet to find data that has verified these claims. We have seen some results that were encouraging, but not definite. One of the systems I tested (not the Jetstar) was problem plagued and has gone back to the drawing board to have improvements made. Will continue testing them once they are ready.
Here is a link to the report summary of some testing we did last year. Click on the report summary, and the product tested was a Jetstar by Dynamic Fuel Systems, which showed no change in fuel consumption.
http://www.feric.ca/en/?OBJECTID=78F2C135-C09F-3A58-EA44AC0FC829D62A
The $200 system is not worth a cent, and is probably dangerous. Remember you are dealing with something that is very explosive, and the commercial systems cost more than $10 k and have many safeguards in place.
Have a great day,
Rob.
So I was just doing some odd browsing the other day, and ran accross this site selling what amounts to a mason jar with an anode and cathode to use Electrolysis to turn water into hydrogen and oxygen gas, which then simply runs through a tube into the intake manifold to be burned in the engine. It claimed to be able to increase fuel efficiency in cars by about 1/3 per mason jar installed. Of course they wanted some $200 for it, which is of course ridiculous, but it looks incredibly simple to make, so I was thinking of making one, and testing it out. The thing that got me was some of the videos of it working, and I was quite impressed with how quickly it created the gas... I would have thought electrolysis was much slower. But, as far as getting better gas mileage is concerned, do you think it will work at all, or could/would it destroy or damage the motor?
Forget all of that high tech electrolysis stuff. If you want hydrogen gas just make it with a simple chemical reaction and capture the gas. You only need several things found in most homes..Its messy and dangerious for a home taught chemist but not illegal and it works.
Forget all of that high tech electrolysis stuff. If you want hydrogen gas just make it with a simple chemical reaction and capture the gas. You only need several things found in most homes..We made it in a science club and filled baloons with it. We may see some do it yourself make hydrogen products for sale in the future. For now you wouldnt want to advertise that you were making it this way though,the enviromentalist would not like the by products .
cheburashka
I make methane gas at home. Haven't figured out how to capture it yet.
Robj
That was last week. This week it's over $4. I can't wait to see what it'll be next week.
Even $4 is a real deal. Up here we pay $5.44 for a US gallon (1.44 per litre todays price) This is just friggin CRAZY. When will it stop??????????????
Have a great day,
Rob.
stevenw00
Although the investment was slightly high, I am halfway to paying off the best fuel saving device I have ever purchased. I was able to triple my gas mileage and within two more years (a total of four) I will have 100% paid for my expenses and will have cut my on going travel expenses (based on $4/gal) from $0.26/mile to $0.08/mile.
My investment: 2005 Harley Davidson Sportster 1200C!
Although it sounds sarcastic, my monthly expensive have not increased at all w/ the purchase of this bike. My gas savings is almost exactly what I was paying in payment and in insurance. I paid the bike off early, but had I continued I would have paid it off in 4 years w/ ONLY money saved in gas mileage. If at all possible, people should really consider trying two wheels instead of four! I love to ride, and although we are supposed to get serious storms today, and I have a 20 mile ride home, I'm still on the bike.
Buy a used bike and you'll save even more! Make sure you check the MPG though, I am getting 48 mpg, but know a lot of people on bikes that are only getting 35 or so.
SgtMaj
Have a great day,
Rob.
Since the price is now being determined more by investors, it will definately be over by January 2nd (no matter who's elected)... the only question in my mind is, how much earlier will it end... after all, investors will try to cash in before it crashes, might have to do that a week before, or maybe 4 months before... no one really knows. One thing I'm sure of is that prices will likely hold until labor day (or is it memorial day that's in the fall? I always get those two mixed up)... after that it could crash anytime, including the day after labor day (or memorial day, whichever is next up).
SgtMaj
NICE! VERY NICE!
I've been looking at getting a toyota prius to commute with... but can't quite justify it in fuel savings... especially with the oil market crash is sure to happen before the next president is sworn in.
stevenw00
I certainly wouldn't count on the oil market crashing by the first of the year. It might top out, but I do not see a big crash in sight.
The Sportster is half as much as a Prius and gets better gas mileage! Not to mention it is a great ride, and cheap entertainment on the weekend (my fiance and I can take the bikes out for a day, spend $20 in gas and have a great 6-8 hr. ride. You can't go to a 2 hr. movie for that!)
SgtMaj
Ohhh... wait and see... A little advise if you have money in oil and you don't want to lose it, pull it out before September. The oil market is a baloon every bit as ready to pop as the dot com's were... and when it goes, it'll burst as fast as a baloon, too.
Robj
Can you arrange for this pop to happen before July. Would be nice to get some relief from these crazy gas prices.
Hope you are right. I too think some type of an adjustment will happen.
Have a great day,
Rob.
SgtMaj
Have a great day,
Rob.
Maybe... http://www.bloomberg.com/apps/news?pid=20601116&sid=ahZTxfdEBZak&refer=africa
Oil demand slacking... oil prices dropping... and the dollar strengthening all in the same article... if investors get nervous, it'll pop sooner. Of course, Goldman Sachs is likely to come out and say they expect prices to hit $160 or higher by the 4th of july or labor day, etc... if the market doesn't respond because it's saturated, they'll turn around and sell their investments which will cause a giant pop in the bubble.
