SuperNova
- Joined
- Mar 16, 2007
- 1,455
Re: Crazy gas saving scheme, will it work?
Now that you are hopefully listening a little better sgtmjr, let me esplains sumting to you. If you disconnect an alternator from the electrical system completely and then spin it...you'll get.....NOTHING. No matter how fast you spin it.....NOTHING. It needs electrical input to excite the field coils to produce output. We control how much output by controlling the input current and voltage. As we increase the load on the alternator, we increase the energy required to spin it. An alternator is capable of increased output at higher RPM...but this is only POTENTIAL capability...it does NOT mean that it just puts out more electricity the faster you spin it. There is an easy test for this.....go to a local garage and have them do a CARBON PILE load test of the charging system...when they load the system...you WILL hear the engine drag down. YOU WILL USE MORE GASOLINE TO GENERATE THE HYDROGEN/OXYGEN THAN YOU WILL SAVE BY BURNING THE HYDROGEN/OXYGEN. THIS IS THE BIG HOLDUP OF HYDROGEN FUEL CELLS. It take more power to get the hydrogen than can be recovered by burning it.
And yes, an alternator is basically an electric motor with the input and output reversed. And a few electrical components added to rectify the AC current they generate into DC current your car can use. Alternator= Alternating Current. We used to have DC generators, but they produced a very dirty sine wave that f'd up fine electronics. But if you removeed those extra rectifying electronics and put power and ground to the contacts you'd get an electric motor.
Stan
Stan
