Re: Cruise Craft Restoration
yep, 1 done with a saw while cutting the floor. Stupid me The other was a 'previous' owner runaground. Now, before you say anymore the saw cut has been done with epoxy resin and will have 3 layers on it. The crack has been filled with epoxy and that section will also have 3 layers over it. The crack is only a inside surface crack, it does not show on the outer of the hull. Also, for the outside of the hull in that whole section, it will be cut back and re glassed. Pics to follow.<br />cheers
