(1) take 4th rod down from top of pic. Put through side of box and build a cam on end.Ok! Next step, in this picture of riding lawn mower parts lies my shift arm/handle assembly. Now to weed thru and decide what to use! Let's see what comes out of it!![]()
Don't over think this...see my simple 'lever"..or ya gonna lose me..(theres a lot of "give' on that shaft...still like yer idea..)
Problem I see is what you think here, going into neutral... will not...it will bounce it over center, and now its either either forward, or reverse, and neutral will be hell to find..if not impossible..(real "dockbuster")
You need a solid shift, with a linkage with solid F/N/R "detents"...
Detents needed? Yes, maybe so,,, I see what you mean, if there's no detent in the shift rod already as it comes out of the LU ???
So, if he removes the springs, & replaces them with solid spacers, so that there's no slop, or sliding movement between the shift shaft, and the long shifter rod,,, or just removes it all, and uses an eyebolt, or swivel (ball joint) here, then maybe he can put sideways slots in the side of the wooden box, to slip the end of the rod into, & rest it there, as detents.
Either way he's usually not online till the early evening here EST, after work.
Myself, I think that pivot/hinge is way to far away. I'm thinking only a few inches, as the shift rod only needs 1/2 inch up/down. Then the shifter can control it easier..(the Fulcrum thing)
But whats nice here, is it can be checked pretty easy, long before the motor covers it all up. Ya don't need water, as no pump involved. Just try it, while someone spins the prop.
That gearbox only has a sliding clutch dog, run off the shift fork. There is nothing in there to stop it (in the way of detents) from going from F to R, or vice versa, as the stock gearshift (with motor) has that somehow figured in the linkage off the side shift handle.
The springs a good idea, but it will just help the shift to continue all the way, neutral passed up. Needs to be more solid of connection, hence, a short pivot, detents of some sort on the handle.
Recently did a Tohatsu 5hp gearcase rebuild. It had an inside the driveshaft rod, spring loaded, with detents, that held in in gear...can't remember much more on it, but it was a way different case.
Anyway, it can be figured out in this case...(pun intended I guess!)![]()
Not needed..just tighten up the nuts on the springs, left the springs. It works pretty good. But I did buy the sleeves today to replace the springs just in case I need them.
Don't worry to much about trashing the shift seal on side/side/move...whatever. No pressure in the case, no water involved, and see no problem with it pushing out oil, even if the seal gets trashed.
Non event.
Didn't know what case you were using, so thats problem solved.
Now, ya need to move the eyebolt in closer...get a better "lever" effect.
You are on the right track. and ya doing DAMN good on the "thinking!. Proud of ya!
I will have to post a pic later when back in the house of when I started the Dragbike .. frame sitting on a box, front end on..thats good, a poster board full size cut out of a Harley Sportster motor..in the living room blocking the fireplace for a month...ashtray fulla cigarettes..hmmm, ..how the hell am I gonna DO THIS! (God, talk about BRAIN OVERLOAD!).
Yer doing fine so far....again, this is a project you remember for life![]()
Hey, It looks good to me! Whatever works for you, but remember in my PM I said that if you put the pivot (fulcrum) in the middle it would be balanced, & the movement, & force needed to shift, would measure the same on both ends, moving it closer to the S. shaft, the handle would have to move more on the end, but need less effort, moving it further away from the S. shaft the handle would move less, but need more effort. If you know what I mean?
You have to determine what works better for you. Still you might need a slotted (detent-holder) on the handle end, to keep it from moving around.
No..zero pressure involved..just the surrounding water pressure.... with half azz good seals....non event...ya aint letting it sit in the water in a slip anyway..top shift seal not a prob, ..just good D/S seals..You read my mind, my next question was about the pressure in the lower unit and if it were to leak would it blow the oil out? I beleive I under stand that there tested pumped up to 15psi and vacumed tested at the same psi, two part test, that sound right?
exhaust:
well I'm not sure, I would think 11/2 " clearance should work. How would you stabilize it? Maybe cover the hole you make with a piece of screen or expanded metal with a hole in the centre to hold the pipe in place. The air going through would help dissipate the heat. Much like a wood stove handle. Your pic looks ugly. Funny, in my mind it didn't .
