Man vs. Boat (season 1).
Pmccraney
Re: Man vs. Boat (season 1, episode 9).
Okay guys. Here is the weekly video update.
If any of the mods happen to catch this, please update my thread title to Episode 9. It used to update automatically when I would change the title of the first post, but something changed and we have been stuck on "5" for the past 4 weeks.
Hope you enjoy.
ezmobee
Re: Man vs. Boat (season 1, episode 8).
The forum software, for whatever reason, only allows you (meaning you, not me) to change your thread title for like a couple weeks or something. After that, what you are seeing is what will happen. I kinda doubt any of us mods will be real interested in updating it all the time for you so you may want to have me change it to something generic.
Pmccraney
ahh... good point. I guess that would be a pain. Let's just go with "Man vs. Boat" and drop all the other nonsense.
thanks EZ,
rpm
gunsup007
Great video! I bet your glad to be done with all the grinding. I'm looking forward to following your rebuild.
oops!
ok.....so where the gash in the gelllcoat is.......the one with light shining thru.....dont worry about it.....just do a gellcoat repair. glass is translucent......the gellcoat stops light from coming thru....where there is no gell, there is light.
as far as you grinding thru the hull........well.....thats it, the hull is now toast.....project over.....sorry.....find another hull.
Pmccraney
Boat wins by technical knock out in round 9, huh?
Nahhh, I'm not giving up that easy (picture rocky theme music playing as I get up off the mat).
I'm still a newbie, but not quite as gullible as I was when I first got back into boat restos, way back in .....when was it......let's see.....September 2011, I believe. Man, time flies..
Jokes aside, oops could you be so kind as to paste in your hull repair methodology here. It would be a good reference point for me and might help others that are following for basic repair tips.
Thanks guys,
Decker83
GRINDING!!! The joy of my life. (NOT)
Hey PM,
I cut thru my hull in a few places. I used the grinder to feather edege out from the hole about 5 to 6 inches. I put some tape over the hole from the outside of the hull. I then used the 1.5 csm to cover the hole about 3" lager than the hole. I cut 2 more peices of 1708, each one about 3" biger than the last one. I put down the csm then the 1708 wet on wet all at one time. I also covered my hull with the 1708. That was overkill. I did alot of grinding on my hull and I felt more secure about doing it this way.
Really enjoy the vids and all your little helpers. Keep up the good work.
Kent
chriscraft254
Bah hahahahah! His grinding days are far from over! Keep up the ggod work. We expect that thing to be splashed in the spring.:)
Outback Jack
Hey PM great job on the grinding...don't let a little grind through set you back...I knew there was damage in my hull before I started but it was not through the hull, but after I took my deck out I found the hull had alot of delamination or I guess bad glass from where the hull hit something. I basically got rid of all the delamination and put fresh glass in there. Yours is by no means at that stage as what I see the glass is good. Basically just need to clean it up and back it up with some materials. Have a look at what I had to do. Anything can be fixed.
Jack
oops!
LOL......i was a little worried about that post...but i knew you were smart enough to see through bud :);)
Thanks guys,
my pleasure.
grinding/cutting thru the hull is something that is going to happen.....even to a veteran. so when it happens, just don't panic.....its an easy fix.
in most of the areas where a grind thru happens, it is because you are intending to lay more glass on top of this area any how. so super special attention to the area is not necessary.
after cleaning out the slice with acetone.....use a resin, filler mix called "peanut butter"
this is a mix of resin, cabosil and milled fibres. there are several examples here on the forum.....some in the hull extension thread, some on the open forum.....
my favourite in this situation is "oops super dooper structural peanut butter" pat pend. tm :D.
http://forums.iboats.com/showthread.php?t=507690&highlight=sooper+dooper
(for other more no structural fillers such as fairing use a different mix, the hull extension thread in my sig, has the recipe for that)
ok.......fill the slice with the peanut butter......let it drip thru the slice and fall on the floor. (put card board or something on the floor.....you cant get this stuff off concrete. it is that strong.)
while it is still wet.....take 2 layers of csm and glass over the slice from the inside......let cure.
now do the repairs to the hull that you were planning......stringers ect.... however.....just make sure that when you are tabbing by the repair area.....just go over the slice with more glass...as you glass over the stringer......glass the slice as well. you want at least two layers of 1708 over the gash......this is easy as the tabbing for the stringer and stringer glass will be this much any how.
forget about the outside till you are done and ready to tackle the outside as a whole.
when you do get to the outside of the hull, grind off the excess peanut butter that has gooped thru the slice. grind the gellcoat off the hull 3 inches each side form the gash.
clean with acetone.......and add 2 layers of 1.5 csm un waxed resin. over the slice....make the second layer slightly larger than the first.
after that is cured.....just take a sander to the area and sand some what smooth....
then do a standard gell coat repair.
the whole repair will take less than one hour. (except the gellcoat phase, that will take a little longer, but not much)
that is it.......beer drinking time:D
cheers
oops
Pmccraney
cheers
oops
Thanks oops... Just to be clear I understand the instructions.... Is it beer drinking time now, or do I have to do the repair first?
Mike Lammert
HaHa, PM, drink now fix later!;)
rrumba
Ensign
+1, to drink now, fix later...........
now i don't feel so bad when i did it myself, ummm, i mean when my son did it on the transom.......
chriscraft254
Beer goes great with peanut butter! :D
jasoutside
Eh, I just noticed your new signature mccraney.
I don't remember seeing HydraSports comment but that is pretty stinking funny:D
GT1000000
Hey PM,
Looking great, thanks for the vid...
As they say great minds think alike...
I was grinding away this past weekend till I got stopped by the local PD for too much dust in the atmosphere, seems a neighbor thought I was causing the sun to stop shinin...;)
Anyhow, I too, cut through the hull, not once, not twice, but 3-4 places, oh well, can't make an omelette without breakin some eggs...as OOPs! says, there ain't nothing you can't fix on a glasser... just need the right ingredients and the right way to go about it...afterwards, good as new...try that with a tinny...Hahaha:D, well I guess you could just reevit more tinluminum on top???:confused:LOL.
I am making a makeshift dust dome for my final{ha ha ha, that's funny, final...yeah, right...} grinding endeavors this coming weekend...should keep me from perpetuating global warming and then I'll actually be ready to begin some reconstruction...
Keep up the great work.
Regards,
GT1M
Pmccraney
Pmccraney
GT1M
Yeah, I was on an iboats Binge last night and saw that on your thread. Sorry to hear about that. Grinding is bad enough, even without a nosy neighbor to deal with. Hang in there buddy....
