Thanks Chris, yep done filter and link/sync. Didnt know you could richen the carbs up on these, outside of jet changes. Would it pick up on the starter fluid if it was lean though?Link and synch?
Replace any fuel filters.
Richen the idle mixture to allow easier acceleration.
Hi Chris,chris, his motor has tha WH's which do not have anyway ta change idle except jetting..
its sounds 'lectric ta me... parts and/or wiring... if ya spray fluid in it and it does nothing but bog its not firing on all cylinders for whatever reason.... fillin' up tha holes but something ain't firin' tha plug??? only hittin' on maybe 3 or 4....
know ya said its all new but sometimes "new" don't mean much..... more true everyday..
and yep, ya need ta check tha flywheel magnets....
did you try ta run it with any of tha old parts on it???
jus noticed something else.. whats your house water pressure???,, not much leavin' tha prop and exhaust at idle???
I think you could be right.. Just been out and tested the coils with an OHM meter. Of the 6x coils, 4 are in spec, the 5th shows very low reading on the meter and the 6th is dead. Will remove the green wires to the coils and re-ya need a spark tester or use your timin' lite ta test for fire on each clyinder off idle..................... or if ya like me i sometimes pull one plug completely out and start tha thing... do all six undividedly... you can wait till dark if ya have trouble seen' any spark from tha plugs.. but i think its 'lectrical.. could be wired wrong?.. could be a bad "new" part???
Nice, liking that, so if you block off the pee hole coming from the poppet it flows more water through the heads and out of the other pee hole?"Now on the one-piece plate the 2.4 dump hole were pretty close to the right size but I still modify them. The 2.5 plate dump holes were all over the place. I have seen some that were so big the motor could not get more than 5-lbs. water pressure at 9000 RPM. I weld up or tap and brass plug all the dump holes in the exhaust plate. The 2.4 will have 4. Two in back and two in front. The 2.5 will have two ridiculously large dump holes in the front. Keep in mind the worst thing for a motor is to run it too cold so don't worry about closing these holes up a little. After I block the stock holes I redrill two new holes in the front of the plate, right next to the other holes, that are 19/64. This will allow proper cooling, good water pressure and still let some heat develop."
this is tha part that effects yours.. pay no attention to anything 2.4.. yours is same as 2.5....... something he doesn't mention.. you can kinda change tha pressure with tha hose commin' from tha poppet cover.. i've run that opening completely closed on a coupla motors justa get tha pressure up....
So got to water test her again today with the new coils - we've made some solid progress. Before it would barely run, now she planes out will run up to 4,000RPM (half throttle) - that's a great improvement. Wouldn't keep running before and had no power. Now she won't pull past 4,000 RPM, falls on her face at throttle positions past that. Literally dies back to idle if you don't lift off, but recovers if you do. Runs all day below 4k RPM though which is good. Tried bumping the choke at speed to see if that helped, made it slightly better, but barely any change.you are describing exactly tha way some act straight outta tha box from merc with tha way it cools.. we called it "consumer R&D"....
yep... restricting tha discharge from tha poppet will slightlt increase tha pressure with most motors but not all.. it still depends on tha drain holes in tha adapter plate...
