Miss Peachtree
Lakeshadow
Re: Miss Peachtree
IMAG0709.jpgCalculating leverage, ratios, clearances, displacement, balance, in my mind among other things...Thinking of liquid fresh water.... Tool drawer facing outboard directly under rear bench.:)
Streetgang
Re: Miss Peachtree
I have been following your restore and finally looked at the Chris Craft video. That is just priceless. Keep on keeping on.
Lakeshadow
Re: Miss Peachtree
Thanks a bunch Streetgang. I sure appreciate it. It floors me to find something that amounts to a high horsepower engine, trans, rear end, tires, for two hundred bucks. Ya know what I'm sayin'. Up till Miss Peachtree my hobby was vehicles. Lovin' it...
Lakeshadow
Re: Miss Peachtree
IMAG0723.jpg Instrument panel for Miss Peachtree is currently contemplated...
I've got a no seam instrument case visual in my head.....
Lakeshadow
Re: Miss Peachtree
GT1000000
Re: Miss Peachtree
I really like where your "choo-choo" of thought is heading...
Nice job cutting those out...
Lakeshadow
Re: Miss Peachtree
IMAG0895.jpg Touch off diameters, transfer pattern depth of .125 or so n I'm down with that...IMAG0897.jpg Speed and cutter is off yet table saw peeled threw forged alloy with just warm chips....
Trooper82
Re: Miss Peachtree
I see someone was a toolmaker or machinist...I bet that aluminum chattered like the dickens on the table saw!
Streetgang
Re: Miss Peachtree
Scared me for a bit there...
Thought perhaps put the Streetgang curse on you where ur thread goes to la la land
but oh contrar, just a Shadow process of planning.
Good stuff, just keep on keepin on once again.
Lakeshadow
Re: Miss Peachtree
Naw Troop, the material cut very nice, just speeds and feeds. Adjusting the feed was easy, I would of preferred to slow the "tool" saw blade, speed down some, yet not possible, until I invent it, hey an idea. I have carbide cutters for the mill I mill alloy with all the time, they're the greatest. They leave a finish somewhat like the saw blade does.
I did spend a few years working in a machine shop during layoff's though.
Lakeshadow
Re: Miss Peachtree
Hi Street. Yea, see what ya mean, pic on right is trimming down the jack plate pieces. Left is the instrument panel. Just transfered mounting locations into gauge pods.
Lakeshadow
Re: Miss Peachtree
Pods on instrument panel face held on location exactly as they will end up being screwed into place.
Mahogany holes shimmed with masking tape finding location between instrument panel face and gauge pods. Thus drilled fastening holes in pods with pre-existing hole locations
GT1000000
Re: Miss Peachtree
That is going to be one classy looking instrument cluster...very nice!
Lakeshadow
Re: Miss Peachtree
Why thank you Commander.
+ or- a c hair....
Jack plate all jacked up...
supports my weight without a creek...
IMAG1063.jpgalready.
Lakeshadow
Re: Miss Peachtree
It's been a while. Is this droid phone the upload problem? The coolest picks won't upload....
Machining clearance for wires in the instrument panel and final milling on the tool box drawer....
Trooper82
Re: Miss Peachtree
Looking nice!
Is that a vertical mill or a beefy drill press?
Lakeshadow
Re: Miss Peachtree
Here's the jack plate finished. A 3/4" plank of mahogany bolted in between. I sawed the plate down as much as I could, realizing the 150 maximum horsepower rating for it was way too much for this 13.5 footer. A 33 pony Ski-Twin will be used this year. Eventually I want to move to a '71 40 pony selectric.IMAG1359.jpgYes Troop, it's a mill.
With all the different horsepower offerings there is, as outboards seem so similar looking with close to the same power outputs. I wonder if there is anything that can be done to say my 33 Ski-Twin to bump up the ponies to close to 40 horses? Such as modify the timing advance stop for more spark advance? In other words wondering if the factory incorporates limits to keep the horsepower as advertised.
GT1000000
Re: Miss Peachtree
Hi LS,
Instrument panel and jack plate, both look absolutely amazing...Beautiful work.
Sorry, I can't help with the boosting of power on the OB, if it was a regular 'ol car engine, however, well that's a different story...;)
:D
