Moving a 30ft boat 450 miles on a converted mobile home trailer
avenger79
Re: Moving a 30ft boat 450 miles on a converted mobile home trailer
Please do understand though that your 1500 chevy is NOT up to the task. Air bags and better brakes just don't make it so.
Cool project.
that was my first concern as well but the boat has no drivetrain so it may well be within the capacities of the truck. trailer = a couple thousand pounds and the empty boat a couple more.
my half ton pulls 7000 pretty well. as long as he has good brakes on her and a good running drivetrain he should be alright. if the 1500 is a V6 with a 5 speed we'll see him on the news.
Utahboatnut
If you do end up pulling with your 1/2 ton:eek:make sure the truck is ready for the task as well. Truck tires good, cooling system in order etc. Not that the boat will be super heavy with no powertrain but there is still some weight there thats alot of wood and alot of side force from winds. I think I would inspect each bearing over just jacking and trying to see if there is side slop. A good clean and repack would be a minimum for me as well as a few good spares. If you have access to air I would deflate the tires a bit and then check for sidewall cracks etc while they are partially deflated, then air back up to mfg. reccomended psi and recheck when you return so you know if they are losing air. Also check out the brakes on the trailer if you are trusting just the truck brakes you may be asking alot of your truck plus its probably not legal, so if there were an accident you would be liable. Which brings up one other point does your auto or homeowners policy cover anything on this, if not and something happened you could be in a real bad spot if someone got injured and you had no insurance. Good luck with it all that is a cool old boat for sure.
Gary H NC
Those mobile home tires are tough...like 8 ply i think.
I used to use them on an old flat bed trailer to pull all kinds of heavy loads.
Most tire shops would not touch those kind of rims. I just bought a couple spares from a local mobile home hauler.
Silver Eagle
If it were my boat I'd pay someone to haul it., Let someone who knows what there doing get the headackes. Use the extra money saved to buy your motor or other things you'll need later down the road. Do you have insurance on all this ?
dave11
if it were my boat i'd pay someone to haul it., let someone who knows what there doing get the headackes. Use the extra money saved to buy your motor or other things you'll need later down the road. Do you have insurance on all this ?
insurance?????????????
avenger79
so did you move it yet? when is this going to happen?
87Spyder
Ive seen this boat on Clist before. If you haven't moved it yet and need any help to get rolling I am in Vancouver and can help, let me know.
MTboatguy
@dave11 Thats a VERY good point. If I haul it (Going to research these boat movers) I am going to take it through Oregon on I84 all the way across and then to 395 N. Problem being, I have never been that direction and I have no clue what bridges are where.
Oh, I know I can make a call to the DOL and answer this question, but maybe someone here knows. When I do the paperwork for my oversized load permit and actually get the permit. Do I have to have the trailer licensed, or can the oversized load act as a trip permit?
First of all the route you have chosen, will be just fine, I have traveled that route many times and there are no bridges that will present problems for you, unless you are taller than the semis that travel that route, those are both routes that are set up to handle a lot of truck traffic. I 84 is used all the time to transport large boats, I mean big tug boats..the Columbia River runs right along it for a good amount of the way, and they move them C. River tugs between towns on that road, once you hit 395, there are very few over passes and they are set up as well for big truck traffic. so the trip route should be fine.
You will need to call Oregon DOL to get their current regulations, they seem to change them quite often and the OR State Patrol can be a real bugger to deal with at times, you might have to have your trailer inspected as well as be able to supply the gross weight on a load of this nature, and they may check your tow vehicle to make sure you are within the ratings of the tow vehicle, I have had them do that, when I was moving Park Model RV trailers(basically small mobile home)
Another thing you need to be aware of, you might need a pilot as well as a chase car, make sure and check with ODOL on those items, they will want to know the width of the load, I am surprised that WADOL didn't ask about it..
Hope that helps.
PS, Make sure your tow vehicle is 100%, there is a bugger of a hill once you cross the river into WA as you go past the weight scales, that thing can kill the best of tow rigs if there is any problems with it, and then there is a steep long grade going down into Tri-cities, make sure your brakes are in good condition and the brakes on the trailer is working at 100%(You do have brakes on the trailer, Right?)
Another thing, make sure that boat is sitting in cradles on your trailer or the first turn you hit, it will roll on you no matter how many straps you have!
That boat actually looks like my great grandfathers old boat that he used to gill net on the Columbia back in the 60's if not his, one very similar and he hauled his with old beat up Ford 1/2 ton!
BrandonHa
Thanks fellas for the help! Sorry it took me so long to post back. Got home last night and I was worn out from the drive.
I did the deal, she is bought and paid for now. I got back home last night from Vancouver. We went fishing after that and I did not have any service so could not post. I was thinking I would just tether my phone to the laptop to get my iboat fix.. ha!
I am going back in 2 weeks in my own truck (Vs riding with a friend like this trip) and I think everything that I need. I am going to budget $1,000 for it.
I think it was like 35 miles North, Northwest of Longview. I cant pronounce where I was and I would mangle it if I tried to spell it. I can say it was rainy and service was non existent :D
All 4 tires are hammered. I would not even trust them to get half way to the tire store.
So I am thinking that I will buy 5 tires and wheel's or maybe 6 if i can afford it. Have them mounted over here and bring em with me. Then change them out before I leave for home. I am going to do it over 2 or 3 days. That way I will have 1 or 2 spares for the drive home. (that was a good suggestion)
We stopped quite a bit on the way home and it took 12 hours. That was with several stops along the way but also we were doing 75mph. I think pulling the boat I am going to keep it at 60. If I am remembering right, thats the legal speed I have to stay at. Besides it even being legal, I know I wont be able to stop to fast so 60 seems safer anyway.
I am going to change the wheel bearings before the drive also. From what I understand its very easy to do. I have never done it, but my friend said that it was simple enough.
As far as Oregon goes, I looked very briefly and it looks like they are similar to Washington. Will be calling them on Monday first thing and asking a lot of questions.
@MTBoatguy Brakes.... I learned something that I think is interesting in regards to the boat looking familiar to you. It is documented vessel with the Coast Guard. I left the paperwork in my friends truck on the boat yard who built her. It was made in 1975 and has not had as much as 1 rain drop on her since then. A lot of boats that I saw there had a similar hull. Wouldn't that be neat if it came from the same boat yard as your grandpas? When I get the paperwork from him I will post the name of the boat yard who made it.
I said in an earlier post that he pulled it with a v6 Toyota. I was wrong, he pulled it at 55mph with a 4 cylinder Toyota! Only like 12 miles, but impressive none the less.
The trailer has electric bakes. The plugin on the trailer is the flat one, same as my truck. The boat is huge, no way in *^#! I would tow it without brakes. I knew it was 30ft of course but the over all size of 30ft did not sink in until I got there and saw her. She is a beauty by the way! I cant even tell you how excited I am to get it home.
http://forums.iboats.com/showthread.php?p=2937303&posted=1#post2937303
Question about trailer breaks. What is it that I have to do with my truck to make it compatible with electric trailer brakes? I have yet to google it, will do that this evening. Is there certain ways that are better then others in regards to installing that brake controller in my truck?
BrandonHa
Thank you! I might take you up on that. I will no more over the next few week days. Tomorrow is football and Sunday. The couch is already calling my name :D I will be back on it Monday.
BrandonHa
Monday I will start the paper work for oversized load permits. Still gotta find out about Oregon's laws though. I dont know if the permit process takes very long. I told the fella that I bought it from that I would need 2 weeks.
Hopefully the permitting process does not take to long.
I am thinking first couple days in October is when I am going to move it. Hopefully sooner though
superpop
Have you gotten a quote for a pro to do it yet. That is a big heavy boat, even without the drive train. There are some wicked hills and a mountain pass (Satis Pass I think) that you will need to drag this monster up and down, and that is what burns up an underpowered truck. I would bet that one breakdown will eat up any savings from having it done by a pro. And, god forbid there is an accident, you will be liable because you are clearly towing way outside of the CGVW of the truck, and your insurance will not cover anything if that is the case. I am certainly no expert but based on the pics, that trailer hardly looks ready to traverse 450 miles, even with new tires and bearings. How are the welds, are the beams all solid with only surface rust or is the thing full of cancer. Do the brakes work good, all the lights work ect. Just seems like a lot less hassle to hire a boat mover, and probably safer. Sorry if I sound negative, this just seems like a huge risk to try what you are contemplating.
superpop
I do love the pink hull though, if you leave it that color I think you should name it the Pink Panther.
BrandonHa
I have not gotten a quote yet but I am going to. I dont take your comments as negative, I think you bring up some good points.
Going on I84 there is no big pass though. Its reasonably flat. I got this nifty little app for my android called "My tracks" and its written by google. If you have a droid I highly recommend it. It logs your position and tracks the elevation. When you go back and look at the log file it shows you your elevation incline or decline in a nifty chart along with the speed you were traveling at when you were at that elevation. We just did the drive in both directions to make sure it was the best route. I only recorded the route for 3/4 of the way though.
I think I can actually share the route I chose through google maps. I will have to look in to that. I know there is an option to share, i just have not tried it yet.
Back on track. If the breaks dont work then I will not do the trip. Or I will pay to have the breaks done. Besides going through a yellow light once in awhile (We only have one light here in town) I am a by the book kind of guy.
With the insurance deal, I have no idea about how the insurance works but I would assume if I can get permitted legally in Oregon and Washington then my Insurance will cover me (state farm). The boat is not insured yet as I just got home last night. You can be guaranteed though that I will have her insured for everything I can :). So far (about 21 years now) State Farm has treated me awesome. I dont really see any problems with insurance but I am by far an expert on it.
So I braved the darkness just now and went out and checked my door sticker. It shows the GVWR as 6600/2994. Remember that I have after market airbags in my leaf springs and bigger breaks. I was looking for the paperwork on my airbags but could not find it. I paid $680 for 2 airbags in the leaf springs, the amount of weight I could carry went way up. I dont know how this works legally though as far as increasing the GVWR. Does anyone know? Its a 1997 Chevy k1500 that is build to pull serious loads. The 350 under the hood is plenty of power ;)
How do you calculate the weight of a boat besides actually weighing it?
About the trailer, its flippin awesome. I went through one end and came out the other. I have been burned on this not to long ago, so its safe to say I am paranoid. The trailer is awesome. Its got all new lights / wiring. Besides, that electrical stuff is easy to work on. OOOOH.. I forgot. The trailer has been licensed and inspected. Heavy welds on the trailer and just some minor surface rust.
Follow this link below, then scroll down on that thread to see the links to my youtube videos I just put up tonight. You can get a better picture of it then.
http://forums.iboats.com/showthread.php?p=2937721#post2937721
Ok going to bed now :)
BrandonHa
LOL.. I was thinking "The big pinky"
Could you imagine the innuendos.................... :D
reelfishin
Now that you mention your driving a K1500, my concern now is whether or not your transmission will endure 400 miles of that kind of load? With or without a trans cooler or what every suspension mods you made, the most common trans in a K1500 is a 4L60E automatic, which by no means was meant to pull that kind of weight. If your truck has the larger 4L80E or any of it's more modern derivatives then you have a chance if your very careful.
As to the flybridge, I don't think it looks all that bad but I see two concerns, one obviously is if it stands over 14' on the trailer, the other is wind resistance, both on the road and on the water. That thing will act like a giant sail. The flybridge will also cost you plenty in extra fuel both for the tow home and on the water.
How tall does it measure from the ground to the top?
Most semi trailers are within 14' tall with a few going near 15' tall but that's not common anymore. Keep in mind that manufactured house movers travel the highways too, many of them build to 16' tall and use only limited access roadways, often without permits in some western states. You might want to call one of them for advice on the route too. I worked for a guy moving buildings for a few summers years ago, we generally kept everything to within 15', at that height you can usually maneuver around obstacles enough to get through most towns. (Lifting wires, tilting stop lights, etc.) But on the highway your limited to the overpass heights. Also keep in mind that some lanes offer more clearance than others just due to the slope in the road, also keep in mind that the marked height may not always be correct if the road has been paved recently. We used to carry a measuring stick with a red mark at the height of the load we were carrying plus 3" to allow for inclines under the overpass.
Its hard to tell by the pics but it don't look 14' tall. If that boat measures under 13' 9" tall, I'd have little worry in my mind about it going down the road. At 10' wide you may not even need a permit, I do know that some western states don't require one until you exceed lane width. Texas for example I believe was 16' for trailers and 20' for housing on a trailer. Things change though when you get into a small town environment. But unless your hitting street lights or wires, I doubt they would bother you, especially if you call ahead and ask. We often had small towns just send a car out to help direct traffic if we asked.
If your over the 13' 9" height, I'd think about carrying either a couple of air tanks or a good air compressor in case you need to lower the rig by letting air out of the tires. Doing so can buy you up to 4" or so if needed.
I also can't help but think that you may be better off just calling a boat mover, it may be cheaper in the long run. Or else, call a heavy duty towing company, one that regularly moves buses and heavy equipment, it may be a whole lot cheaper to just have it slid onto a low boy and hauled for you. Keep in mind that those new tires you buy, probably about $550 or so, will likely just age under the boat while you work on it over the next few years. That would be money better spent on something else on that boat, as would money spent fixing the trans on your truck.
A few years back I had a motorhome hauled from TX to NJ by truck, they loaded the thing on a flatbed and delivered it to me here for $1100. That was over 2400 miles. I called a local heavy duty towing company and they found a guy that would bring it to them. They did the work and no doubt made some profit off it but considering the thing had a blown rear axle and wouldn't roll, I thought it was pretty fair overall. I'd have spent that much just going there and back in my truck, burning my gas, plus hotel stays to deal with the move. That 400 or so mile run may turn out to be far cheaper than you think and leave you with more money in your pocket. Keep in mind that times are lean now and you may find someone that really needs the money.
The way I see it your looking at $550 or so for tires, plus rims if you didn't take the old rims home with you when you were there.
Gas there and back, (I'd figure with that thing behind a 1/2 ton truck that gets 10 empty, your looking at about 5 or 6 tops heading home, so figure closer to about $400 for gas.
Then figure your time, the wear and tear on your truck, which if it's got a 350, isn't very new, and then you will have to deal with old electric brakes which may or may not work.
If you had a bigger truck I'd say the brakes may not be too much of an issue so long as one axle had brakes but you will need good brakes pulling that thing. I also think 60 mph will be optimistic at best. I hauled a 22' enclosed car trailer about 200 miles once with a 95 C1500 with a 350 and 4L60E trans. Any incline was an issue, hills all but stopped me, and there are no big hills around here. The trans fluid was burnt and the trans failed a month later even though I babied the thing the whole way. Luckily the truck was new and under warranty. I got it fixed and bought a diesel to pull the trailer. There's big difference to being able to move a big trailer and being able to do it over a long haul without damage to the truck.
Since you already made the deal, you most likely have limited time to move the boat, I'd start calling both boat haulers and tow companies. You may find that a tow company will be far cheaper. If the boat is secured well to the trailer, they should have no issue with getting it on a flat bed low boy trailer. If you do intend to loose the flybridge, doing so now will no doubt lessen the hauling fee if its over height. They can also lower the trailer on the flatbed by both removing the wheels or dropping the wheels into the deck. One hauler near me here has a deck that has removable panels to allow for tires to drop down to lower the overall height. If that were me hauling that, I'd load the boat and trailer onto a lowboy trailer, tilting it to gain the most height and then pull off the wheels and block up the frame of the trailer and bind it down. Chances are if it leans forward, the highest part of the flybridge will be a lot lower, maybe even as low as just being pulled behind your truck. Tilting that thing forward and removing the wheels may lessen the height by two feet or even more.
As much of a feeling of accomplishment it may be to say you hauled that yourself when it's all over, it's a matter of cost and good business sense to just let a pro handle it. Any legitimate business whether a boat hauler or towing company will have insurance to cover the job as well. Being that the boat is only 10' wide and only 30', and the fact that it's already fitted on a trailer I feel it's more the territory of a heavy towing company than a boat hauler. A boat hauler will usually have a hydraulic trailer for moving boats that are in dry dock. They may not even have a good way to remove the boat from the trailer on site, it may still have to be towed to a marina to be lifted off with a gantry crane and set on their trailer. Whereas a tow company will just load and secure the boat and be on their way. You will need to know the full measurements and approximate weight of the boat when you call around to get an accurate estimate.
BrandonHa
Found some 8 - 14.5" WITH wheels for $25 each on Craigslist. I gotta sweet talk the wife out of some more boat money. So if I never post again its because she buried me under the house :D Just kidding honey... Even if I have someone pull it for me I will need tires and $25 each I am going to buy 8 of them. Cant go wrong with 4 spares right?
Is there an easy way to see what transmission I have?
A transmission cooler is on my list of todo's for this week. The tranny cooler has been on my list of things to do for a year now (since I had the airbags put in). The stupid part is they are cheap and from what I understand easy to install.
The boat is under 14'. If I recall we figured it at about 13. That was without a tape measure though. I tried hard to remember everything I would need for the first trip and I left the tape at home. I was not really in the position to run down and buy one because I was riding with my friend and he was due to meet his family.
Thats a very good point about the wind. It gets nasty down there through the gorge. I imagine it would be something like driving a sheet of plywood through a hurricane.
I was using this 'my tracks' app on my phone to record the route home and make notes along the way. There was 1 tunnel and there was plenty of semi's going through it so I think it will be good to go as far as height and bridges go. I did not put a note in on the tunnel but paid attention and I am sure there is no issues with it.
In Washington state anything over 8' 6" is by the book required to be an oversized load. You dont see hardly anyone that abides by that law. I *think it was 14 and over also required an oversized load permit. Even if I dont do the haul over here and have someone else do it I will abide by the rules when I go to the lake. We live very rural and just a few miles from Lake Roosevelt but there is no shortage of state police. Even worse would be hurting someone.
I was looking at a chart the other day that had all of the states and the restrictions and now I cant find it again
The gal at DOL in Washington told me that she was sure I would just fall in to the category of the $10 permit for a one time trip. But when I got the boat finished she recommended that I pay $20 a month for a permit that is unlimited use and only requires the oversized load banner. She told me it was a permitting process though so that was subject to change.
Chapter 7 is Wasington, Chapter 5 is Oregon
http://www.wsdot.wa.gov/NR/rdonlyres/0C56F372-1F81-4993-9286-186EDD693CF0/0/M3038_06.pdf
$1,100 to have it moved from TX to NJ? Wow! I wish Monday morning would hurry up and get here so I can get on the phone and start calling.
Your guy's input has really helped me a lot, just want to say thanks again and I want everyone to know that I have read every word of everyone's response and put thought in to all of it!
Is there any way to calculate the approximate weight of the boat?
Oh yeah, the biggest time constraint is winter coming. It gets cold and snowy here. I really should be fine through October but if I am wrong and myself or someone else is pulling it and gets stuck in the snow that would really suck for everyone. I did tell him 2 weeks also, so it important to me to keep my word.
BrandonHa
My door sticker.......
BrandonHa
Being Sunday night I did not figure I could get a hold of anyone but thought I would give Enterprise Truck Rental a call.
It was hard to get details from the guy on the phone but he said they did rent "Large" trucks. This was the 888 number and not the office but it was promising anyway.
$191 for 4 days, unlimited Mileage within the Northwest (pretty much Northwest, a bunch of states that I dont plan on being)
I dont know what they define as a "large truck" just yet and even if towing is allowed but it was promising
191Seanymphstriper
Can you please call a couple of boat haulers and post there prices up to do this move for you....
Just so we can all compare to how much you are saving versus risk!
