Re: Need help with transom repair w/pics
This is where I am right now.... I am attempting to re-attach the part of the cap that I had cut off in order to get to the transom. I had to do some modifying to the part because my transom seems to have grown this summer and is a bit thicker then it was from the factory.
I tried to think of different ways to cut it to fit and this is my plan which is going to probably make some of you glassers out there cringe. I am going to use a PB mix to attach the cap to the top of the transom and then fill in the gap so that it is even across the top and down the front of the transom.
Then I am going to take some 1708 and attach it about an inch above the black line in this pic and then double it over onto itself and up over the cap to create a straight line on the transom where the cap would have ended.
This is what I am going to attempt to do and I am not sure how it will come out since I am not very good with glass.
